Old 11-06-2010, 10:06 PM   #1
Default 220 outlet
Hi I know im not an electrician but i have a question I have a 220 dryer outlet I dont use in an old laundry room I made into a workshop. I want to hook up my miller tig welder. can I just change outlets to match the welder. the dryer outlet in the fusebox has a double 30amp breaker. thanks
1welder is offline   Reply With Quote
Old 11-06-2010, 10:07 PM   #2
Chief Electron Relocator
Old 11-06-2010, 10:08 PM   #3
I void warranties
Jlarson's Avatar
Call an electrician.
The best never stop learning.
Old 11-06-2010, 10:11 PM   #4
PGW Professional
Magnettica's Avatar
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
YouTube Video
"I have two ceiling fans for you to hang. Should take you only 10 minutes."
--Actual customer
Old 11-06-2010, 10:13 PM   #5
That Guy
Mr. Sparkle's Avatar
Old 11-06-2010, 10:14 PM   #6
B4T
ET Road Warrior
B4T's Avatar
What is the "service man" carrying in his right hand.. last time I saw a tool like that there was a dike attached to it.. Brian can explain..
Old 11-06-2010, 10:17 PM   #7
You've never seen nunchucks?
Real electricians use 'em to beat sense into DIYers.
Old 11-06-2010, 10:19 PM   #8
Send a message via Yahoo to doubleoh7
Tie the microwave into the stove circuit. The stove circuit is 240 volts. That is what you need to operate your microwave correctly. I bet that your hot dogs are taking too long to cook in the microwave, aren't they.
Problem solved, next question please!
doubleoh7 is offline   Reply With Quote
Old 11-06-2010, 10:21 PM   #9
All I want is an answer every thing is fire proof as I have welded in the room before
Old 11-06-2010, 10:22 PM   #10
Exasperating Member
JohnR's Avatar
I almost bought one of those soldering irons at a tag sale a little while ago. just to hang on the wall and pretend it was 480's
Old 11-06-2010, 10:23 PM   #11
We'd like to help you, but this is a site for electricians only, not DIYers.
Old 11-06-2010, 10:25 PM   #12
In all seriousness, just go to your local Lowes or Home Depot. The home improvement expert working in the electrical department will be able to explain what you need to do, how to do it, and can sell you all of the materials needed to comlete the job.
Old 11-06-2010, 10:37 PM   #13
PGW Professional
Magnettica's Avatar
It may be fire proof but is it fire resistant is the real question.
--Actual customer
Old 11-06-2010, 11:27 PM   #14
ADMIRAL STARFLEET COMMAND
BEAMEUP's Avatar
Send a message via MSN to BEAMEUP
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
BEAMEUP is offline   Reply With Quote
Old GE gfi outlet BIGRED Vintage Electrical 13 11-08-2010 12:41 AM
Old Outlet BIGRED Vintage Electrical 22 06-17-2010 02:06 AM
Microwave outlet BIGRED General Electrical Discussion 18 03-20-2010 05:22 AM
Power Outlet OneLittleBoy Residential Electrical Forum 2 03-24-2009 03:45 PM
outlet katessa General Electrical Discussion 13 04-21-2008 08:08 PM
