08-10-2012, 05:14 PM
240V Lightning or Surge Protectors
I am looking for a 240V protector to use for a 240V well pump. All the surge and lightning protectors I have found need a neutral. There is a 10/2UF going to the well house. I wanted to put protection out at the well house as well as at the home. I really don't want to tie the neutral of the protector to the egc. Anyone know of something out there for this purpose.
08-10-2012, 05:26 PM
A MOV should do the trick. Available in 250 and 275 volt. Put this across your feed. Have to select the amount of power dissipation you require. Simple to use to suppress power spikes but good luck with lightning strikes.
08-10-2012, 05:34 PM
Dennis, if the above suggestion doesn't work for you at the well, then try this, it's out there and for this purpose.
10/3 and a shovel/backhoe
Well (no pun intended) you asked.lol
niteshift
08-10-2012, 05:42 PM
Thank you-- I went to the site that sells them and they are asking all kinds of info. that I have no idea. http://www.mouser.com/Passive-Compon...FcGf7QodGXAAqA
08-10-2012, 06:38 PM
08-10-2012, 06:43 PM
I void warranties
Use the pre package protector not individual MOV's. Especially since you can put the pre made unit in a knock out so if it pops after a surge there won't be blown up MOV in the box.
Putting the white wire on the EGC won't hurt.
The best never stop learning.
08-10-2012, 06:54 PM
Originally Posted by nrp3
Those are what my suppliers sell but I assumed the white wire had to connect to the neutral.
Thanks all
08-10-2012, 07:01 PM
Can't Remember
What got me thinking about those was the little grey round things hanging off panels or well pump equipment. Now that I look at the specs closer, it shows all the wiring going to neutral, but in the specs it shows L1,L2,N/G so I'm not sure what to think. Sorry
08-10-2012, 08:19 PM
You can use neutral or ground with these, or none.
08-10-2012, 08:21 PM
google MCG surge protection
08-10-2012, 11:56 PM
God-fearing Volt-head
All original content licensed via the OWL ( http://owl.apotheon.org) from date of post.
Electricity is like water: the smallest amount can kill you, it's hard to control, and life is impossible without it.
