Old 03-12-2012, 12:45 PM   #1
child please.....
NolaTigaBait's Avatar
Default 3 doorbells
Anyone have any ideas as to wire 3 doorbells?...Everything is #18 doorbell wire. I have a 30va 16v transformer, it works great for the 2, but it wont drive them with the 3rd wired up. Is a 40va transformer the soution here or is that too many chimes for this setup?
REMOVED
Old 03-12-2012, 12:47 PM   #2
Chief Electron Relocator
I'd just up the Va of the transformer.
Old 03-12-2012, 12:49 PM   #3
child please.....
You think a 40va will work?...Im trying to find one online but all i see is 24v secondary @ 40va...Im pretty sure the chimes are 16volt
REMOVED
Old 03-12-2012, 12:52 PM   #4
No way for me know know if 40Va will work or not.
Another option is to incorporate an ice cube relay with a 16v coil and a second transformer.
Old 03-12-2012, 01:03 PM   #5
child please.....
Thats a new one...
REMOVED
Old 03-12-2012, 01:09 PM   #6
child please.....
I wouldnt even know where to begin with that setup.
REMOVED
Old 03-12-2012, 01:14 PM   #7
Default What are the ohm readings of the door bell solinoids?
I am not a electrican, but a datacom tech. Regargless, I did pass a very intense avionics program long ago.
If you put three bells in paralell, the total resistance will be less then the smallest resistant in the parellel circuit.
Do you know what the guage wiring is used for the bells?
Try and do a calculation of the resistances
1
________ Get back to us with the answer with the ohm
1 1 1 Remember, the voltage drops in each leg, but not
__+__+__ Current in a parallel leg.
R1 R2 R3
lortech is offline   Reply With Quote
Old 03-12-2012, 06:12 PM   #8
1
R1 R2 R3
? complicating it too much
I don't see the 40va being a problem but when in doubt go with the 50 lol
CanadianSparky is offline   Reply With Quote
Old 03-12-2012, 07:27 PM   #9
Default yes mabey ;)
I never heard of a three door bell system but maybe its a huge house? Quick hurry, run to the door. sprint the 100 yards
I wonder if a intercom would be more appropriate?
Old 03-13-2012, 08:41 AM   #10
Something odd here...since only one button gets pushed at a time, why would it matter if you had 2, 3, or 50? How are you wiring in the 3rd button?
Whatevva is offline   Reply With Quote
The Following User Says Thank You to Whatevva For This Useful Post:
hardworkingstiff (03-13-2012)
Old 03-13-2012, 08:47 AM   #11
k_buz's Avatar
He has multiple chimes.
k_buz is offline   Reply With Quote
The Following User Says Thank You to k_buz For This Useful Post:
Old 03-13-2012, 09:22 AM   #12
still in business
sbrn33's Avatar
I have upped the trans to a 24 volt with no real bad results. normal chimes though, no musical or electronic ones. I bet a 30va 24 volt might be a cheap way to solve your problem.
Until some little **** holds the button in for a couple minutes. haha
Stop trying to think logically, it won't help you here. Just do as we say and everything will be alright.
Old 03-13-2012, 09:36 AM   #13
child please.....
I called nutone and the "tech" told me to parallel 2 30va transformers. I dont know if thats a good idea from what ive read on here... I may try that 24v one...they are just standard solenoid style chimes..
REMOVED
Old 03-13-2012, 12:09 PM   #14
jw0445's Avatar
If you bought chime kits I would try paralleling both of the kit transformers rather than buying another one.
jw0445 is online now   Reply With Quote
Old 03-13-2012, 12:16 PM   #15
I have never had an issue with 3 chimes on a 30 watt trany. What kind of chimes are you using. I use a nutone LB-14 recessed chime
Old 03-13-2012, 05:31 PM   #16
child please.....
Some off brand the supply house has. I need to check on that.
REMOVED
Old 03-13-2012, 06:45 PM   #17
If it is a class 2 circuit it would be a violation to parallel it. I assume 3 chimes that must ring together and not 1 chime with 3 tones for different doors?
Get a larger transformer if it is 3 chimes to ring together. 24 volts for really long runs will partly deal with VD if the chimes are 16 volts.
2 Doorbells, 1 pushbutton TOOL_5150 General Electrical Discussion 24 09-01-2011 03:03 PM
