30 degree offsets - Electrician Talk - Professional Electrical Contractors Forum
Old 05-31-2010, 11:35 PM   #1
Default 30 degree offsets
How would one figure out the minimum size offset you can make using the 30 degree bends? Obviously there has to be a minimum size because of the size of the bend. Is there a chart?
If we use 3/4" EMT as an example, the takeup for a 90 bend is 6 inches. So 1/3 of that would be a 30 degree bend, or 2 inch takeup. Is that the same as the offset amount?
Conduit Phil is offline   Reply With Quote
Old 05-31-2010, 11:42 PM   #2
william1978's Avatar
Rewards Points: 2,000
I thought you were conduit Phil???????
The Following User Says Thank You to william1978 For This Useful Post:
slickvic277 (06-01-2010)
Old 05-31-2010, 11:45 PM   #3
mattsilkwood's Avatar
Rewards Points: 2,006
On a short offset like that I like to use 10s. It makes it easier to pull.
A man that will not read has no advantage over a man that can not read.-Mark Twain
Old 06-01-2010, 12:14 AM   #4
Phil,
If you need a 10" offset, using 30deg. bends, you need 20" between bends.
Is that your question ?
Ok, the smallest offset would be the measurement from the arrow on the
bender to the front of the bender.
Frank, Arizona,USA
It's what you learn after you know it all that counts
Benaround is offline   Reply With Quote
Old 06-01-2010, 12:16 AM   #5
I own stock in FotoMat!
Rewards Points: 6,520
It's all just math. However, you're thinking it's a linear relationship, and it's not.
If the take-up of ¾" EMT is 6", then you could make a 360° circle with a 6" radius.
So what would the circumference be? Pi*r*2. 3.14*6*2. 3.14*12. Or 37.68".
So a 360° circle is 37.68" in circumference. From that, you can calculate how much of that is used in each 30° of arc. Double that for an offset.
Old 06-01-2010, 12:41 AM   #6
Been a while since math class... 360/30=12. So there are 12 30 degree arcs in a circle.
37.68/12=3.14
3.14 is the minimum offset? Not sure why you'd double it. You are kicking it one direction and then back the opposite.
Thats close to 4 and the guide on porcupinepress.com says "30º bends are too great with most hand benders for offsets less than 4" center to center."
Old 06-01-2010, 06:40 AM   #7
Speedy Petey's Avatar
Rewards Points: 2,266
Because using 30 deg bends you double the offset for your bend points. Using 45 deg bends you use 1.8 times the desired offset.
Huh??
You take the conduit out of the bender and turn it around? That is not how most people do it. Not unless you have to that is.
Heck, using 3/4" I cannot see how it would be physically possible to get bends closer than roughly 4".
Old 06-01-2010, 08:32 AM   #8
What kind of bender do you have? I've always used 1.41.
Old 06-01-2010, 09:00 AM   #9
480,
37.68/12=3.14
You double it because, well, you need two bends to make an offset.
Old 06-01-2010, 09:07 AM   #10
Rewards Points: 2,050
Stop confusing me with such facts.
Old 06-01-2010, 09:15 AM   #11
OK, Bob. Just for you, I'll let you make 2½ bends.
Old 06-01-2010, 09:39 AM   #12
Bending takes to much time anyway just 'bow and go'.
Old 06-01-2010, 10:53 AM   #13
Fried Bologna um um good!
jwjrw's Avatar
Nah just warm up the pvc blanket and shape as needed
Old 06-01-2010, 07:27 PM   #14
You must really get around. I've seen your work all over the place.
Old 06-01-2010, 07:28 PM   #15
Rewards Points: 960
Hey Phil,
There is no chart that I know of. The min. offset would vary with each size conduit and bender type.
To determine the minimum offset on a specific bender/ conduit size, Multiply the amount of offset desired by the cosecant of the angle desired: (30 deg = 2; 15 deg = 3.86; 10 deg = 5.76). This measurement must be enough to line up the second bend mark on the correct center mark for the angle desired- (this will NOT be the star mark for a 90 deg stub), and have enough conduit to have the first bend mark about one pipe diameters past the end of the shoe. This is way easier to demonstrate than to explain.
I always mark my hand benders with the center marks for 5, 10, 15 and 30 degrees. This makes bending faster, more neat, and easier to match multiple runs.
On my usual 3/4 ENT bender, a 2 inch offset on 30 degrees is the minimum offset. I would normally bend any 3/4 EMT offset, less than 3 inches, on 15 degree or less bends. It looks neater and is easier to pull wire.
Does anybody remember the days of concentric bending?
varmit is online now   Reply With Quote
Old 06-01-2010, 07:49 PM   #16
Senior Moment
rlc3854's Avatar
Rewards Points: 514
Originally Posted by varmit View Post
Hey Phil,
What's a do hickey
rlc3854 is offline   Reply With Quote
Old 06-01-2010, 08:01 PM   #17
On that note, does everyone prefer 30 degree offsets?
After this job, I'm beginning to rethink my use of them.
Granted, they ran 1/2'' pipe where solid 12's and 10's were being pulled through, but to prevent pulling fiascos like that in the future, I'm considering stepping it down to at least 22 1/2 as a baseline.
Old 06-01-2010, 08:21 PM   #18
Rewards Points: 960
I prefer 15 degree offsets myself, as long as they are not huge. They do make wire pulling a lot easier, especially if I am working alone.
Old 06-01-2010, 09:56 PM   #19
Duh.
I knew that but wrote it wrong anyway.
Old 06-01-2010, 10:06 PM   #20
Rewards Points: 5,198
I like the 30 degree bends. As long as you don't give into the temptation to overfill the conduit it should be no problem. Teaching others the way around a Chicago bender is easier and the learner will remember that, and how to figure the gain and the loss of that bender, and how much loss you have to figure into the calculations to be able to cut and thread a straight piece of pipe before bending a 90 degree and an offset on the same piece. Just my opinion.
How many sizes of 1/2" offsets are there danickstr General Electrical Discussion 19 04-24-2010 05:07 PM
Say what! SE-R under 60 degree C. columun partimer31 NEC Code Forum 16 03-21-2010 06:35 PM
Is a college degree worth it? shenanigans Off Topic (Non Trade) 13 08-21-2009 12:29 PM
How do i go about getting an Engeneering degree? crackerontherun General Electrical Discussion 7 06-19-2009 11:44 PM
RMC offsets into threaded hubs MDShunk General Electrical Discussion 21 02-21-2007 10:07 PM
