Old 02-18-2009, 06:30 PM   #1
I'm new.. but I ain't old
Default 320A meter, 200A meter, disc grouped?
Hello all, new on the board.
Here's the deal..
Have a garage (3 car) which is going to have a 320amp meter. This will feed one 200 amp main breaker panel inside the garage, and one 200amp disconnect in the garage.
From the disconnect, it'll feed to the separate building (residence) which is about 100' away into a 200A main breaker panel.
The 200A panel at the garage will feed the garage/art studio and a 100A feed to a transfer switch.. which then feeds to the separate residence and will be along side the 200A panel, into a 100A panel.
Here's the kicker..
There will also be a 200A meter along side the 320A meter.. and this will feed a 200A main breaker panel for the mother-in-law apartment which is below (1 window sided basement) the garage. This apartment is existing and will effectively be a panel change.
Question is..
Do I need to have a 200A disconnect up where the other 2 are at?
Grouping? Is this required, or is it treated separate because of the separate service.
I'm thinkin' it needs to be grouped with the 2.
Marcopolo is offline   Reply With Quote
Old 02-18-2009, 06:56 PM   #2
I am thinking that also.
Welcome to the forum.
Old 02-18-2009, 08:57 PM   #3
ceb58's Avatar
You may want to look at 230.2 I do not believe you will get away with it. You will have two services on one structure. Unless I am mistaken with what you have described. Your only other option would be set a trough and tap to a meter and disco for each location.
ceb58 is offline   Reply With Quote
Old 02-18-2009, 11:26 PM   #4
Originally Posted by ceb58 View Post
You may want to look at 230.2 You will have two services on one structure.
I will have one service lateral connected to two meters. This is ok with the local utility, and I believe is not a violation of 230.2
Tags
320, buildings, separate
Elec meter 5' from a gas meter heel600 General Electrical Discussion 18 11-23-2008 05:43 PM
PSE&G meter key heel600 Tools, Equipment and New Products 16 11-08-2008 11:34 AM
what meter should I get ToddH General Electrical Discussion 13 10-30-2008 08:28 PM
Wanted: In Need of Meter gilbequick Electrician Swap 23 07-26-2008 09:40 AM
I have to buy an Amp meter shotdown General Electrical Discussion 3 08-02-2007 06:55 PM
