Old 01-23-2012, 06:35 PM   #1
Default AAON control wiring and Johnson Control
Does anybody have any experience with the AAON RTUs and the way Johnson Control wires them up. I have all the external devices done and have the cables needed for the RTU up to the unit but where to land them, I have no idea. There is a terminal strip with a bunch of labels but I can't seem to make heads or tails of it.
Things that need to be made up:
Supply Fan Enable
Supply Fan command
Heating Enable
Heating Command
Cooling Enable
Cooling Command
Filter Status
Supply Air Pressure
Return Air Pressure
This is a 30 ton unit if that helps.
Any information would be helpful. I have called Johnson Controls and told them I would like a field guy to come in and run through it with me but they have yet to call back.
Thanks once again.
jculber is offline   Reply With Quote
Old 01-23-2012, 07:06 PM   #2
360max's Avatar
http://www.aaon.com/literature.aspx?id=12
360max is online now   Reply With Quote
Old 01-23-2012, 07:13 PM   #3
sparkie2010's Avatar
Send me the single line diagram
Today is a Wonderful DAY!!
http://www.solaristechnology.net
sparkie2010 is offline   Reply With Quote
Control wiring books william1978 PLCs, VFDs, Motors and Controls 11 11-04-2010 06:48 PM
Control wiring, way its done brother General Electrical Discussion 34 10-28-2010 06:41 AM
Step one in wiring a control panel petek57 PLCs, VFDs, Motors and Controls 27 03-22-2010 01:11 AM
I need help with a control wiring circuit (homework) Ant PLCs, VFDs, Motors and Controls 14 05-22-2009 12:23 PM
Wiring In Generator Control Switch limey_swindon General Electrical Discussion 1 01-07-2008 07:16 PM
