Old 09-24-2008, 05:21 PM   #21
I have a quick question? Can we install a ground wire on the exterior of a cable to create a isloated ground? We currently have romex feeding outlets but we may need to install isolated ground receptacles in order to keep electromagnetic interference in check.
Any Help?
aphase08 is offline   Reply With Quote
Old 01-04-2009, 05:18 PM   #22
i have a serious ground fault issue i need help with. had an electrical fire caused by a falling branch on the service of the home. power was fed through the ground wired of the home melting several, catchin the a/c on fire, and blowing out lights. if no damage seems to be apparent on some circuits, should they still be changed to prevent long term issues?
rj_cavalier is offline   Reply With Quote
Old 01-06-2009, 02:06 PM   #23
Electrician in Sacramento
What a great post, very helpful infomation
Dave Hufstedler
Serving the Sacramento Area.
Electrician Sacramento
davehufsted is offline   Reply With Quote
Old 01-15-2009, 08:23 PM   #24
Shunt trip
Default Great info!
Well written information.
shunt trip is offline   Reply With Quote
Old 03-05-2009, 09:06 PM   #25
Default Good Posting mate
G'day mate!
Just wanna say well done on your brilliant posting. It help clears up some misconceptions...
Cheers,
Down Under Sparky....
Veritask Electrics Pty Ltd
Perth, Australia
perthman33 is offline   Reply With Quote
Old 03-10-2009, 12:02 AM   #26
zappy's Avatar
Default Thanks brian!
I had a couple of questions. 1. I noticed you said phase to phase touching is not a bolted fault? I thought that was a bolted fault? 2. I noticed on the gfpe that the dial said from .1 seconds to 1.0 seconds, why would anyone want to set it to 1.0 seconds?
"In thee abundance of water, the fool is thirsty"
zappy is offline   Reply With Quote
Old 03-10-2009, 11:01 PM   #27
Phase's touching is not a bolted fault, a bolted fault would be two phase BOLTED together, such as parallel feeders with two conductors from different phases crossed and connected.
2. I noticed on the GFPE that the dial said from .1 seconds to 1.0 seconds, why would anyone want to set it to 1.0 seconds?[/quote]
In attempt to coordinate with downstream devices, risking additional damage to the distribution system.
Old 03-12-2009, 02:53 PM   #28
zappy's Avatar
Default Thanks for helping me learn
What is it called then when two different phase's touch? Just a fault?
In attempt to coordinate with downstream devices, risking additional damage to the distribution system.[/quote]
What is it called when two different phases touch? Just a fault?
Old 03-12-2009, 03:27 PM   #29
What is it called when two different phases touch? Just a fault?[/quote]
phase to phase fault.
Arcing ground faults are so devestaing due to the impednace of the arc and the voltage levels that permit the arc to maintain. These are burning arc faults and can in a split second totally fry busway, switchborads and feeders without tripping the overcurrent protection. The fault levels are in the low current range hence the NEC requirement for 1200 amp max.
Old 03-13-2009, 05:51 PM   #30
in the uk we fit an earth rod with an apropriate rccd prpotection star system find more help at www.mylocalelectrician.co.uk
lazer is offline   Reply With Quote
Old 03-13-2009, 06:11 PM   #31
In the states several systems are utilized, what you described is a ground return method, we install a Current Transformer on the main neutral ground bond this system is called the ground return method. Then there is the zero sequence in which a large window current transformer encompasses all phase conductors and the neutral/grounded conductor. Lastly the residual method comprised of 4 current transformers one on each phase and the neutral/grounded conductor. This is mandated ONLY on systems 250 volts to ground and higher and above 1000 amps (typically 480/277 VAC).
Old 04-06-2009, 08:45 PM   #32
Better Electrician
Very interesting, I had know idea that ground fault protection has been
around since the 70's.
Travis Hanson
www.BetterElectrician.com
Better Electrician is offline   Reply With Quote
Old 04-08-2009, 10:03 PM   #33
I'm new to this thread business and can't seem to figure out how to ask a question...perhaps because I keep alcohol in the house! I'm not an electrician by trade, however I have limited training as one. I am trying to power an antenna with an i/o box requiring 1 phase 230 v ac. I am working with 208v off of a wye configured transformer. I intend to wire this antenna with 2 hot legs from my power source and cap the third hot leg. I am wondering if this will cause any problems...antenna az/el motor performance issues. The motors on the antenna are 3 phase 220 v and are fed from the aforementioned 1 phase 230 v power box. I assume this power is rectified within the box to power the motors. This post may be vague but would appreciate any replies.
Vick1311 is offline   Reply With Quote
Old 05-11-2009, 08:00 PM   #34
Question
I have a simple question on ground rods. At work we recently had a guest instructor tell us the way to megger a ground rod was from the panel neutral to the rod. He said we should get over 400megohm reading between the 2. This does not seem correct to me. What is the correct way to megger a rod and what is the correct ohm reading.
shelly50 is offline   Reply With Quote
Old 05-11-2009, 10:28 PM   #35
Shelly:
Not only is he wrong he is dead wrong. I can't imagine where he read, heard or was taught this.
Read this and print a copy for him
http://www.aemc.com/techinfo/techwor...GROUND-WEB.pdf
breaker issues eveishas General Electrical Discussion 7 10-19-2008 01:47 PM
Brotherhood Issues randomkiller Union Topics 186 05-27-2008 09:07 PM
Seroius Clearance Issues VegasVolts Code Violation Discussion 13 02-03-2008 08:55 PM
Ground Fault Location Equipment for Ungrounded AC Larry Tools, Equipment and New Products 2 09-15-2007 10:55 PM
Ground Fault Installation brian john Code Violation Discussion 4 05-30-2007 12:57 AM
