AFCI nuisance tripping - Electrician Talk - Professional Electrical Contractors Forum
Like Tree30Likes
Old 09-23-2008, 06:33 PM   #1
Default AFCI nuisance tripping
I am looking for any documentation regarding nuisance tripping of AFCI circuit breakers. Have a customer who is unable to use the vacuum in any of the five bedrooms in her house. The house was built in '02 or '03. Thought I might try replacing a 2002 afci breaker with a newer model. While at supply house, Eaton rep happened to be there and he said the issue is the vacuum, not the breakers. Not that the vacuum is defective or "wrong", just that those particular motor windings are incompatible with the afci. They are CH style bkrs. I asked for more info and he got back with me later in the day. " I couldn’t find any literature right off hand but we have people in Pittsburgh that do nothing but trouble shoot AFCI issues.
Please give them a call while you are at the house with the homeowner to troubleshoot the problem."
Just curoius if anyone has any input, short of me telling the lady to buy a new vacuum...Thanks
crk1a is offline   Reply With Quote
Old 09-23-2008, 07:13 PM   #2
Rewards Points: 2,012
Try another one,vacuum. seriously.But don't buy one,
The only equipment problem that I have had with AFCIs' (not CH) were 110 v smokes. Found 2 once that the breaker did not like.
most likely a fault in the equipment. Perhaps the surge of the unit starting.
Old 09-24-2008, 06:24 AM   #3
JohnJ0906's Avatar
I've had problems with vacuums and AFCIs before myself.
Luckily, these were larger homes with a bath in each bedroom, so I could suggest using the bath receptacle to plug the vacuum into.
Majewski likes this.
John from Baltimore
"One day at a Time"
Old 09-25-2008, 09:01 PM   #4
Default issues
We've had a ton of issues with arc faults, espically when people are doing finish carpentry, its the windings in the motors of alot of these things that arc when started and throw the breaker. Had an inspector tell us 2 weeks ago, once its inspected do what ever you want, leave em in, take em out, whatever. haha. But ya we've had alot of issues. One house actually had to replace a handful of them, homeowner would leave, come home a few hours later and a handful of arc faults would be tripped.
kawaikfx400 is offline   Reply With Quote
Old 09-27-2008, 08:18 AM   #5
I say nice try, but the problem is actually with the breakers. Are these vacuums and power tools causing or creating arc faults? …No!
Are they causing 30 mA ground faults? …No!
AFCI’s are truly untested, unproven, unreliable and unnecessary technology that has been foisted onto the electrical trade and it’s customers. The original series AFCI’s were a pant load and the new Combo AFCI’s are even more so. They are as close to 100% pure BS as you will find anywhere. They are in no way as significant or equivalent in importance as the development of the GFCI was or is like so many attempt to relate and to compare them to. All of the laboratory and field-testing for these is biased, irrelevant and useless.
If the NFPA really wants to save lives, they should find a way to limit the effect of portable electric space heaters in old buildings with already antiquated wiring systems, such as by lowering the wattage ratings that these can be manufactured at.
The annual onslaught of fires from the use of these because of overloaded electrical wiring and contact with combustibles will begin next month, when the weather starts getting colder and fuel prices continue to rise. Should be a banner year!
Old 09-27-2008, 10:17 PM   #6
Rewards Points: 1,000
I agree with KayJay.
Old 09-28-2008, 04:03 PM   #7
Default h
Its all about the manufacturers. They make these products and then push them into the code book to make money. Just like tamper resistant plugs, joke,same with having arc faults everywhere,joke. Just another way for someone else to make money.
Old 09-28-2008, 06:14 PM   #8
kbsparky's Avatar
Those early AFCI breakers are mostly junk. In most cases where we had nuisance tripping like you described, replacing the breakers solved the problem.
We had one case where the vacuum worked on one bedroom circuit, but tripped the breaker when plugged into the next bedroom circuit. Replacing the offending AFI breaker fixed that one.
We often times have had AFI's tripping with no apparent load on them. Before taking the circuit apart, we have learned to remove all load wires from the breaker and test again. Too often the blasted thing will trip out with no wires attached to it at all!
These were all Cutler-Hammer Eaton products, the instigator (read: LOBBYISTS) who force-fed these into the Code!
The Following User Says Thank You to kbsparky For This Useful Post:
Timtoolman (11-05-2011)
Old 09-28-2008, 08:53 PM   #9
Rewards Points: 462
I agree with the others, arc-fault breakers are just another way manufacturers have legislated the use of their products. Or should I say legislated their profits!
It seems these days that just about anything can be sold in the name of safety, and our elected imbeciles will force it upon the public, whether we like it or not. There seems to be an awful lot of safety theater, safety products, safety talk, etc. which is nothing more than a smokescreen behind which the government gains even more control of the people.
20 years ago it was environmentalism. The California wildfires,, among other disasters, have proved the foolishness of the concept of 'Rule By Zealots'.
The same idiocy is happening to our trade, and the victims (that'd be you and me) have been rendered completely powerless to oppose it.
Sadly, Rob
Old 09-29-2008, 01:35 AM   #10
cdnelectrician's Avatar
Rewards Points: 1,018
We have had a lot of problems with Cutler Hammer's AFI's too. I don't like any of Cutler Hammer's products...SQ-D all the way.
Old 07-09-2016, 07:27 PM   #11
Rewards Points: 16
I am out on an older drilling rig. They have a living quarters house with a single phase three wire panel. The place was once a deer lease.
The original feed pot coming in was a 25 KVA single phase one. So, the single phase 45 KVA dry transformer we are using to feed the building now isn't too much different.
The problem with this thing which more than likely was there to begin with the older service is that a GE panel has a main disconnect breaker that keeps nuisance tripping when they go to use both the wash room and the AC at the same time.
The AC system runs from a two pole 40 Amp breaker to the condenser unit outside and a single phase 30 Amp breaker to the evaporator unit up in the attic. The wash room has its own 40 amp two pole breaker that feeds a dryer and a reasonable size washing machine.
None of the smaller breakers are dropping nor the main disconnect is falling when either set of items are run by themselves. But, when the AC and the washing machine and or, dryer are used at the same time, the main disconnect often falls. But, sometimes it doesn't.
40+40+30=110
Main disconnect breaker is a 215 AMP two pole unit.
Do you think that this main disconnect is too small for the loads placed upon it and may have been a problem all along? There are a couple of other 20 amp breakers in the panel as well for other loads in the building.
musibike is offline   Reply With Quote
Old 07-09-2016, 07:36 PM   #12
Rewards Points: 2,364
40+40+30=110
These stated currents,
are they running currents ?
Are you taking into account starting currents ?
Starting currents can easily exceed two times the running current.
Maybe try a slower trip breaker
As we call them here in Australia - "slow-blow".
These are designed to cope with short term overloads
as can be experienced with motors starting.
Old 07-09-2016, 08:02 PM   #13
Rewards Points: 292
Anytime I have encountered this issue a newer arc fault has solved the problem
Flytyingyaker is offline   Reply With Quote
Old 07-09-2016, 08:54 PM   #14
Rewards Points: 16
This is what I expected. The unit is an older ARC FAULT type device. A new one will more than likely take care of it.
They have also put in four new computers with large switching power supplies in them. That leading power factor could be goofing things up for this disconnect maybe as well.
At least the AC works. They just have to go and wash in town for now.
So, I will head over to the electric parts store Monday and swap it out.
Thanks guys.
Old 07-09-2016, 10:20 PM   #15
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,229
Thanks guys.
There is no such thing as a 215 amp arc fault breaker. Your question has nothing to do with arc faults.
emtnut likes this.
Obey your Master.
Old 07-10-2016, 08:42 AM   #16
Band Member
emtnut's Avatar
Rewards Points: 7,050
I'm thinkin it's a GE-THQP215
I swear to Drunk ... I'm NOT God
Old 07-10-2016, 01:18 PM   #17
Jhellwig's Avatar
Could be but he is talking about a dryer and ac and tripping the main. I have no idea what he wants.
Obey your Master.
Old 07-10-2016, 02:15 PM   #18
Band Member
emtnut's Avatar
I have no idea either ... hopefully the 'electric parts store' will fix him up
Old 07-10-2016, 05:16 PM   #19
Rewards Points: 16
This thing is bigger than a dual 15 Amp breaker. It has a couple #2 wires going to it from the main feeder panel in the generator house.
If the parts house don't have a reasonable replacement I will shoot a picture of it and post it here this week.
Old 07-10-2016, 10:17 PM   #20
Jhellwig's Avatar
Are you an actual electrician?
Obey your Master.
difference between the afci breaker and the new combination afci jorgymux0048 General Electrical Discussion 24 03-30-2014 08:37 PM
Hot Tub tripping gfi berkey General Electrical Discussion 15 06-24-2013 06:53 AM
Breaker Keeps Tripping? FinsUp General Electrical Discussion 4 11-14-2008 09:44 AM
Tripping NRG General Electrical Discussion 5 08-15-2008 07:48 PM
Tripping problems giarc84 General Electrical Discussion 4 12-20-2007 02:57 PM
