11-11-2009, 07:43 PM
aluminum conduit - 400 cycle system
I'm running 1'' - 2'' aluminum conduit for a 400 cycle system and the specs call for all aluminum fittings. It looks like I'm stuck with 3 piece couplings or (unions), as I have been unable to find threadless compression or set screw couplings in aluminum or zinc in that size range.
Anybody know a manufacturer?
11-11-2009, 07:46 PM
Sounds like a aviation test facility.
11-11-2009, 08:14 PM
Licensed Journeyman
11-11-2009, 08:43 PM
Navy training facility, T&B makes 1/2"-1" zinc set screw for rigid , Topaz has 1/2",3/4", and skips 1 1/4" - 2". Topaz also has 2 1/2" -4" in set screw.
A couple of days ago - discovered thin wall has the same OD as rigid in
2 1/2" - 4"
11-11-2009, 11:24 PM
when you get stuck in an impossible situation and you can't find out what you need, find out where the base maintainance shop is and find out who the old tool is there and ask him what the last guys there used. those guys are the ones going around the base fixing all the crap that breaks, and when they aren't fixing it they are driving around laughing (or crying, or complaining) at some of the work that gets done, so they will most likely tell you how you should do it (whether you want to hear it or not).
Chuck Norris sleeps with a night light. Not because Chuck Norris is afraid of the dark, but the dark is afraid of Chuck Norris.
11-12-2009, 08:46 AM
Lurker...
If Zinc is acceptable, try http://www.bptfittings.com
Larry
11-12-2009, 11:37 PM
We're on the cusp of completing 5 MRI rooms where everything had to be non-ferrous. We've got nylon rod and nuts, fiberglass strut, and stainless beam clamps. I believe someone already posted the Hubbell link. Try typing aluminum fittings into Google and you'll be on your way. Unfortunately, I was unable to use threadless fittings (hospital spec) but the aluminum conduit is a joy to bend.
11-13-2009, 12:11 AM
Lurker...
How does the steel gland ring or set screw work out in each fitting? Is there any issue with that?
Larry
11-13-2009, 03:06 PM
Senior Estimator
Yes - Any time you encircle a 400 hz cable with a ferrous (magnetic) material it causes significant voltage losses from induction. Are you familiar with induction?
11-13-2009, 03:39 PM
Lurker...
Yes I am. However, I am not aware of any 100% aluminum or zinc setscrew or compression fittings which meet the requirements of UL 514B (the governing specification of cable and conduit fittings).
Usually the set screw or gland ring are the steel components in these fittings. Of course you could use 100% PVC or fiberglass, but then the OP wanted all aluminum.
As an installer, you almost have no choice to thread all the aluminum conduit and use readily available aluminum or zinc threaded hubs & 3 pc. couplers.
Larry
11-13-2009, 06:30 PM
Senior Estimator
Reason: spelling
11-13-2009, 06:45 PM
Lurker...
 That's a THREADED aluminum Coupling fitting - The OP was looking for THREAD LESS Aluminum Fittings.
Like these...They are not made without steel components (as far as I know).
COMPRESSION TYPE
SET SCREW TYPE
Understand?
Larry
11-13-2009, 06:53 PM
Senior Estimator
That's what I get for not going back to the original question.
11-13-2009, 09:16 PM
Doesn't Abuse Scotchkote
Look for Killark Electric GU/UN series. They are available in Aluminum.
We use a lot of these. I know there are other manufactures that have them but I can't think off the top of my head.
Charlie
11-13-2009, 09:18 PM
Wow, that must be some interesting work to do!
11-14-2009, 08:55 AM
Lurker...
Charlie
They are threaded fittings. Doesn't anyone read the original post?
Larry
11-14-2009, 01:20 PM
Not Peter D
You should know by now that typical forum behavior is to provide an answer without ever reading the OP or other replies.
11-14-2009, 02:16 PM
#18
Lurker...
I can *hope* for *change* can't I??
Larry
11-14-2009, 05:38 PM
#19
Sorry I misread your original post. Where I come from aluminum conduit is threaded. We thread our conduit when it is cut and do not use threadless fittings.
Charlie
11-14-2009, 05:59 PM
#20
Senior Estimator
I just talked to my favorite GF who has done quite a few 400 hz systems for me. He has always had to use 3 piece couplings as the specs never allow set screw or compresion couplings. He has never heard of a non-ferrous set screw or compresion fittings.
