08-14-2011, 08:53 PM
Good at being Evil
Another round about question
Type UF and type NM have the same conductors. I had both in the same box and both had identical unmarked type thhn/thwn conductors. Why do the manufacturers fail to mark the conductor type on these cables ?
08-14-2011, 08:57 PM
Because theyre not required to.
08-14-2011, 08:58 PM
Chief Electron Relocator
If they were unmarked, how do you know they were THHN/THWN?
08-14-2011, 09:29 PM
ET Road Warrior
If the conductors were marked.. 1/3 of the posts on this forum would not of been needed..
It has been a long running debate what type of insulation is used in NM..
08-14-2011, 09:35 PM
Originally Posted by B4T
............It has been a long running debate what type of insulation is used in NM..
The answer is simple: 90°C insulation.
08-14-2011, 09:37 PM
ET Road Warrior
Since when is 90 0C a type..
08-14-2011, 09:45 PM
The type of cable us the "type". The can build it with any thermoplastic conductor insulation that fulfills the requirements of the cable type.
08-14-2011, 09:49 PM
PGW Professional
It's PVC
"I have two ceiling fans for you to hang. Should take you only 10 minutes."
--Actual customer
08-14-2011, 10:07 PM
As opposed to 75°C 'types' and 60°C 'types'.
08-14-2011, 10:18 PM
Heavily Armed Member
Originally Posted by Magnettica
It's PVC
Can you install PVC Inside PVC..??
08-14-2011, 10:20 PM
Originally Posted by HARRY304E
Why ask why?
08-14-2011, 10:34 PM
Originally Posted by MDShunk
Why ask why?
I don't know why but if someone knows why then someone else will find it in the code why it is not allowed .
08-14-2011, 10:40 PM
I install copper and aluminum inside of steel all the time.
08-14-2011, 10:56 PM
Do you use the steel as the EGC..??
08-14-2011, 11:31 PM
Yepper!
