Old 04-28-2009, 10:26 PM   #1
Tapeman's Avatar
Default Arc fault/ X10 issues?
Has anyone experienced issues when using any of the remote switching systems such as: Insteon, Radio RA, Z-wave, X-10 pro, etc. ?
I have to install some on arc fault circuits.
Tapeman is offline   Reply With Quote
Old 04-28-2009, 10:44 PM   #2
3rd Generation
MF Dagger's Avatar
Insteons haven't been a problem so far for us but we haven't installed too many of them.
MF Dagger is online now   Reply With Quote
Old 04-28-2009, 11:04 PM   #3
Default Chargers interfere
Arc'f shouldn't be a issue ,but older phone charges can create noise in the lines and effect the x10's.Just some info.Also once did an up grade on a very high end house and ran across a problem took 4 service calls to figure out.An old black and white tube chaise,the old tight wade had in his work shop put out so much noise on the lines the house almost seemed haunted
acmax is offline   Reply With Quote
Old 04-28-2009, 11:10 PM   #4
Surridge Electric
We don't have to use ark fult in wisconsin per are state code (comm 16) so I, and most people around here, know much about them. The majority think they would a waste of time and customers money. How similar are they to GFI's if at all?
1991 Storm Trooper is offline   Reply With Quote
Old 04-28-2009, 11:24 PM   #5
Default This is Electrician Talk???
Article:210 2008 NEC.210.12 read it and weep
Also any local jurisdiction can up the codes,and rarely ever lower the standard. Be safe .Think.Work. Live.
Old 04-28-2009, 11:58 PM   #6
Surridge Electric
Ya I know... I've read the articals and know the installation requirement, just not 100% sure on how they function. It almost seems like it works the same as a gfi. No one around here can give me a straight answer because the state says not to use them. The inspectors don't even know and no one can provide me with documentation. I don't have to worry about in but I would still like to know.
Addressing Ground Fault Issues brian john General Electrical Discussion 53 03-02-2010 08:11 AM
Ballast Issues Hoppy General Electrical Discussion 3 04-05-2009 10:04 AM
breaker issues eveishas General Electrical Discussion 7 10-19-2008 12:47 PM
Brotherhood Issues randomkiller Union Topics 186 05-27-2008 08:07 PM
Seroius Clearance Issues VegasVolts Code Violation Discussion 13 02-03-2008 07:55 PM
