ARGGHHH!!! service panel splicing - Electrician Talk - Professional Electrical Contractors Forum
Old 11-19-2008, 01:30 AM   #1
Default ARGGHHH!!! service panel splicing
Situation: already buried wire running from shed to house service panel (75 feet) is coming up short at service panel ( )...feeds approximately 6 inches into panel. Need to extend/splice approximately 2 feet to make connections.
PLEASE provide sound suggestions.
Thank you!
JJPing is offline   Reply With Quote
Old 11-19-2008, 02:40 AM   #2
2towbot's Avatar
Default Cable Stretcher
Looks like u need a cable stretcher 8-) I been working on a prototype
Splicing feeders in a panel looks like poor planning , got to admit though i have been on the short side a time or 2
Are the lugs on the bottom of the panel?
Can u flip the panel?
Can u lower the panel ?
Dunno just ideas. Inspectors don't like to see split bolts
Good Luck
2towbot is offline   Reply With Quote
Old 11-19-2008, 05:09 AM   #3
ACB
what size is the cable?
in your area can you make a joint in a panel? if not pull it out and put an aproapriate size JB, nipple it into panel and make a joint there.
unfortunately sh** happens, all we can do is deal with it the best way possible.
ACB is offline   Reply With Quote
Old 11-19-2008, 05:45 AM   #4
R.I.P. 2014
If you can't flip the panel as suggested then I would put a box in to hold the splices. I don't like having large splices in a panel even if it is allowed.
Old 11-19-2008, 08:53 AM   #5
Rewards Points: 1,000
Mount a box and make some splices. No big deal, technically, just a pain in the rear for coming up short. It happens.
Can you use the box you are coming into the house through for a splice?
Old 11-19-2008, 11:19 AM   #6
220/221's Avatar
Rewards Points: 3,564
Lower the panel?
There are stealthy butt splices you can use.
but still ................
Old 11-19-2008, 01:20 PM   #7
How big is the wire? Maybe a terminal block? I would go with the butt splice probably, less bulk than split bolts.
worn kleins is offline   Reply With Quote
Old 11-19-2008, 03:03 PM   #8
Mountain Electrician's Avatar
Rewards Points: 238
Thank you!
Cut a j-box in below the service panel. Use power distribution block, or split-bolt, or butt-splice to make your cable extension. I try to avoid splicing in the panel, especially if it is any larger than #2.
Old 11-19-2008, 05:21 PM   #9
Go with a trough. 6"x6"x36" across the bottom and nipple up.I think it would look better than a jb
Marco Electric is offline   Reply With Quote
Old 11-19-2008, 07:12 PM   #10
Rewards Points: 238
Unless the panel is 14 1/2" wide, then a 36" trough would look worse. A j-box could be sized to not stick out on either side of the service panel. If the panel is flush mount, a j-box can be recessed in the wall with a minimum of effort and sheet rock patching.
Old 11-19-2008, 07:22 PM   #11
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,014
hand box mounted in the ground a few feet from the shed panel -
EDITyour post sounds like its short at the house end and not the shed end. is that the case?
Old 11-19-2008, 08:35 PM   #12
on the topic of short wires....
Did a service today. PVC from the meter to the panel. Had 20' of 4/0 XHHN (or W).
Hacked a piece for the nuetral, ended up being about 6 inches long on the panel side. The 2 remaining pieces ended up being exact length in the panel, and needed less that 1" cut at the meter.
Talk about luck!
heel600 is offline   Reply With Quote
Old 11-20-2008, 05:06 AM   #13
Rewards Points: 1,464
Bet you sweated all the way up to the happy ending.
Old 11-20-2008, 06:06 AM   #14
Rewards Points: 238
Talk about luck!
I always say, "I'd rather be lucky than good!"
Old 11-20-2008, 06:13 AM   #15
JohnJ0906's Avatar
I tell my apprentice, "Sometimes it's good to be good, sometimes it's good to be lucky!"
John from Baltimore
"One day at a Time"
How do you put in a double panel service? Michaeljp86 General Electrical Discussion 19 09-09-2008 02:04 AM
splicing/junction in panelboard gcleary47 NEC Code Forum 4 06-10-2008 02:51 PM
Service Entrance Panel cykoupai General Electrical Discussion 5 02-08-2008 09:26 PM
A UK panel chrisb271 UK Electrical Forum 18 11-21-2007 05:02 PM
Resi service panel ruff MDShunk Services and Service Equipment 24 03-08-2007 05:27 PM
