Old 05-05-2012, 10:37 AM   #1
PGW Professional
Magnettica's Avatar
Default Arizona style!
Doing a service today. This reminded me of how they do it in Az. What do u think?
Old 05-05-2012, 10:39 AM   #2
That's way better than Arizona style. At least they used a connector. If you check the listings on a metal romex connector, they are usually suitable for multiple cables. At least the Arlington ones are.
Old 05-05-2012, 10:41 AM   #3
B4T
ET Road Warrior
B4T's Avatar
I have seen it many times.. there have been threads on here before about what a 2" romex connector is rated for..
Some say it is hack.. some don't see a problem with it.. just another topic that has no ending..
Old 05-05-2012, 10:47 AM   #4
I just checked Arlingon's website and didn't see any connector that can do more than 2 cables.
heel600 is offline   Reply With Quote
The Following 2 Users Say Thank You to heel600 For This Useful Post:
Magnettica (05-05-2012)
Old 05-05-2012, 10:52 AM   #5
The NM844 is listed for use with 10 - 12/2.
Old 05-05-2012, 10:58 AM   #6
k_buz's Avatar
The 844 isn't a metal romex connector.
k_buz is offline   Reply With Quote
Old 05-05-2012, 11:00 AM   #7
I know. I can't find any listings on the metal connectors larger than 1" on Arlington's site, which is weird since they still need to be listed for something.
Old 05-05-2012, 11:24 AM   #8
aDudeInPhx's Avatar
When I saw " Arizone style" my first thought was an image of a completely destroyed busbar that had 1 double pole breaker landed on the only remaining non-damaged bus with every wire in the box landed on it
aDudeInPhx is online now   Reply With Quote
The Following User Says Thank You to aDudeInPhx For This Useful Post:
user4818 (05-05-2012)
Old 05-05-2012, 12:12 PM   #9
itsunclebill's Avatar
Check out the 842,843, and 844
http://www.aifittings.com/catalog/pd...ble_ranges.pdf
Old 05-07-2012, 02:42 PM   #10
In AZ we would have used a smooth plastic snap in bushing to avoid chafing issues. Metal NM connectors are
The Following User Says Thank You to 220/221 For This Useful Post:
aDudeInPhx (05-07-2012)
Old 05-07-2012, 02:46 PM   #11
PGW Professional
Magnettica's Avatar
I was originally going to categorize this thread as the "220/221" way of doing things.
Old 05-07-2012, 02:48 PM   #12
PGW Professional
Magnettica's Avatar
Originally Posted by itsunclebill View Post
The 1" connectors allow for (3) 8/2's in one connector. Seems a bit hackish to me but I'd probably do it if I had to!
Old 05-07-2012, 03:00 PM   #13
Code compliant and the right way to do it. If you can't properly install a metal NM connector without pinching and damaging the cables, then you're an amateur.
Old 05-07-2012, 03:04 PM   #14
There is nothing "hackish" about running multiple cables into a 2" romex connector, other then its basically a listing violation hence a code violation. Inspectors went on a typical rampage against the practice back around the mid eighty's when it showed up as a listing violation and info about that got into the electrical contractor magazines. Before that it was pretty common practice just about everywhere except major cities such as New York and Chicago. The arguments against the practice are pretty weak if you want my personal opinion, however it is a red flag in my area so I haven't done it in years. For panel changes, it is probably a better practice to run multiples (more than two) if the existing one you pulled out was the same way, than to have to stretch cables out to meet listings for two cables per opening...
This is the realm of overzealous city inspectors, and definitely the realm of "home inspectors"..
Still sweeping it up: http://www.myfoxorlando.com/story/22...-still-unclear
Old 05-07-2012, 03:06 PM   #15
I'm of the opinion that it's not a code violation. There was no listing at all on Arlington's site for a 2" romex connector. I swear there used to be one for all their larger connectors that permitted multiple cables, but I can't find one now.
Old 05-07-2012, 03:08 PM   #16
Your right Cleter, there was a listing on their stuff for multiple runs, I put out a fire on one of the forum sites by showing it once or twice. They probably just stopped paying the payola to UL to upkeep it....
Arizona Journeyman eutecticalloy General Electrical Discussion 11 11-12-2011 12:59 PM
To all the members, except the roofer from Arizona. jwjrw General Electrical Discussion 43 08-15-2011 10:36 PM
Southwest flight out of arizona? ce2two Site Help and Suggestions 1 04-02-2011 04:59 PM
Arizona State wishmaster68 Off Topic 25 03-23-2011 06:58 PM
Arizona L-11 kevinsryan General Electrical Discussion 1 07-04-2010 09:06 PM
