Attic work - Electrician Talk - Professional Electrical Contractors Forum
Old 07-25-2010, 09:36 PM   #1
JLA
Default Attic work
All the recent talk about attic work in the heat got me thinking. What is your typical attic work setup like? Do you just walk across the open joists and then kneel on the joists? Kneepads? You take 2x4's up with you to walk across the joists easier? Plywood to kneel or sit on? Do you have a bag specially made up for attic work so you have anything you might need and you don't loose anything? Or do you just run up in the attic and then remember that you need a bunch of other stuff and have to come back down 4 times like me?
What's your process?
JLA is offline   Reply With Quote
Old 07-25-2010, 10:30 PM   #2
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
I have always worn knee pads.. why I have no problems with them now.
I bought some 1X12X4' pine boards at HD I painted blue and use in the attic for those places only a squirrel can fit.
I have a small 12" fan I take into the attic with me.
A 6' piece of 3/4" PVC with #8 bare bent into a hook for grabbing wires.
Most important, I put a gallon of water into the freezer for about (3) hours.
The water jug is half frozen and stays cold for a whole day.
Old 07-25-2010, 10:37 PM   #3
Canadian
kevmanTA's Avatar
When I first started, I was always stuck in attics, all I had was a maglite and a leatherman wave..
kevmanTA is offline   Reply With Quote
Old 07-25-2010, 10:39 PM   #4
I own stock in FotoMat!
Rewards Points: 6,520
Best thing you can have for doing attic work is a helper.
captkirk (08-16-2010), Magnettica (07-26-2010)
Old 07-25-2010, 10:41 PM   #5
I carry a craftsman 19.2 cordless fan, it keeps you cool and blows the isulation dust away from you. I like the craftsman flourescent light too, lots of light, easy to carry. I use an old linesman ditty bag with a belt clip to carry tools/parts. No pads, scrounge for a board if I need to lay on something.
JTMEYER is offline   Reply With Quote
Old 07-25-2010, 10:43 PM   #6
B4T
B4T's Avatar
Even with attics, I never wished I had a helper.
I had one slip off the ceiling beam and dumped a 4'X4' piece of sheetrock on the dining room table.
Only good thing he missed the crystal chandelier by 6"
Old 07-25-2010, 10:44 PM   #7
That's why YOU are in the attic, not some stumble-bumble.
Old 07-25-2010, 10:50 PM   #8
Rewards Points: 3,800
Like this:
And be sure to help steady the ladder when your helper goes into the scuttle...
Old 07-25-2010, 10:57 PM   #9
Like this:
"Does anyone know what time it is?????"
Let's not forget to get a Petzl.
Old 07-25-2010, 11:22 PM   #10
JLA
I always liked the Dewalt 18V Lantern type fluorescent light. It lights up the whole area, lasts for 4 hours on a normal 18V battery, and doesn't make you even hotter like quartz lights will.
Old 07-26-2010, 12:50 AM   #11
Best investment for attic work I ever made was a headlamp.
romexican is offline   Reply With Quote
Old 07-26-2010, 08:16 AM   #12
Bkessler's Avatar
Rewards Points: 2,000
Head lamp, fan, and a bottle of water. Most of the time it's to risky sending a helper in the attic. I end up doing most of the attic work myself.
When ls lunch?
Old 07-26-2010, 08:31 AM   #13
JLA
The fan is a great idea.
It's just that I shy away from taking extra stuff up there because it makes more trips up, more walking back and forth over the open joists, and more time up there. But if I need to be up there for a long period of time, I am definitely going to invest in one of those battery powered fans.
Old 07-26-2010, 08:56 AM   #14
Bkessler's Avatar
I just got a fan a couple of months ago, even just putting it by the attic entrance helps a lot.
When ls lunch?
Old 07-26-2010, 08:58 AM   #15
Start early in the morning in hot weather and know when to quit. Drink LOTS of water. I try to plan what I'll be doing and take all the material and tools up with me. I always need something else. I'll usually just pack around a cardboard box with me junk in it. I don't take tool bags up as I will loose tools. I walk on the trusses and only kneel to do work. I need to find good knee pads.
Old 07-26-2010, 10:17 AM   #16
ichimo23's Avatar
Summertime attic work here in AZ is a blast, let me tell you. Virtually all of the attics here have blown-in insulation which tends to cling to you when you start to sweat. I wear an old nomex airforce jumpsuit, LED headlamp and respirator (the old guys call me 'ghostbuster'). The airforce jumpsuit is great, as it has lots of zipper closure pockets to stash stuff, and velcro cuffs at the wrists and ankles to keep the insulation out. I also bring a change of clothes, and drink a ton of water. Carry up a milk crate for tools/supplies, with zipper tool bags for wire nuts, bits etc. Even with the best of prep, it's still no picnic
ichimo23 is offline   Reply With Quote
Old 07-26-2010, 10:30 AM   #17
reddog552's Avatar
Rewards Points: 127
Default Attic work
Im in the middle of a whole house restoration. House was done in knob & tube with the added extention cord in places. Im replacing all wiring plumming. I live neer St Louie its been 110 with heat index for weeks,Ive spent 30 plus howers in 100 who knows what in the attic. The first thing i did was tap into an air duct and ran a 50' 10' flex ductIhelps some
reddog552 is offline   Reply With Quote
Old 07-26-2010, 12:46 PM   #18
"Boozer"
Innovative's Avatar
huh...... plumming?? howers??
Personally, I use employees to climb in attics..........
www.IEC-Electric.com
www.Hivoltage.biz
"The impossible, is usually the untried"
Innovative is offline   Reply With Quote
Old 07-26-2010, 06:50 PM   #19
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Hey! That's a good idea the pvc and the hook. I also carry a "Blue Blower" fan. Actually, I have two!
Old 07-26-2010, 07:09 PM   #20
Bkessler's Avatar
A snare comes in handy some times when a hook wont do, get a long piece of #12 and stick both ends into a 3/4" pvc until they come out the other side, then pull them so you have a round loop at the end and just pull on the #12 ends on one side to close the loop on the other side. Works good to on wild animals.
When ls lunch?
controlling attic fan? GEORGE D General Electrical Discussion 48 01-21-2016 10:54 AM
Best Attic Suprises Mike Guile General Electrical Discussion 30 03-06-2010 02:45 AM
Attic Romex tie-in rmsowell Residential Electrical Forum 13 11-23-2009 08:49 PM
Firestat for attic ventilator B4T Residential Electrical Forum 4 06-08-2009 05:52 PM
Wires in the attic... waco General Electrical Discussion 5 09-08-2008 09:11 PM
