Old 02-16-2010, 09:36 PM   #1
Default Ballast Problem.
My condo has two 240v outlets. One is 15 amps and the other is 50 amps.
I want to hook up three 1000W ballasts and an air conditioner to run on 240v.
The ballasts use 4.1 amps each and the air conditioner is unknown as of now.
How can I wire this?
I attached one possible solution I think might work.
ice52us is offline   Reply With Quote
Old 02-16-2010, 09:40 PM   #2
For the sake of the safety of the people in the other condos, I suggest you move your grow operation somewhere else.
Old 02-16-2010, 09:42 PM   #3
Send a message via AIM to Murphy
people are just crazy.. hire an electrician.. !
Murphy is offline   Reply With Quote
Old 02-16-2010, 09:47 PM   #4
haha. i thought the same thing as soon as i read that post!
GDK 13 is offline   Reply With Quote
Old 02-16-2010, 09:49 PM   #5
Vintage Sounds's Avatar
What do you suppose three 1kW ballasts and an air conditioner are doing in a condo where apparently the stove outlet is not needed for an actual stove?
Vintage Sounds is online now   Reply With Quote
Old 02-16-2010, 09:53 PM   #6
charlie Bob's Avatar
I had an stressful day. I needed a good laugh.Thank you ice52us.
charlie Bob is offline   Reply With Quote
Old 02-16-2010, 09:54 PM   #7
That was funny! A real solution would be appreciated, however.
Old 02-16-2010, 09:58 PM   #8
Go away.
Old 02-16-2010, 09:59 PM   #9
captkirk's Avatar
Im gonna need a sample first...Please send it in a can of coffee, then in a cardboard box wraped in brown paper marked perishable.Ill pm you address..And please only "kind" no "brown frown" ....Send the sample and youll get your schematic.....LOL
Old 02-16-2010, 10:01 PM   #10
WTF............. dude, you are the Big Daddy Rabbit. You should try to patent that.
bdeots is offline   Reply With Quote
Old 02-16-2010, 10:07 PM   #11
Default Ballast problem
Bear with us here. We get a lot of questions on this forum, and some like yours. Let's get to know each other. How long have you been in business in OK?
Inductor or ballast monus76 General Electrical Discussion 3 07-25-2009 04:14 PM
Ballast after Ballast shazam General Electrical Discussion 25 05-29-2009 10:35 AM
Replacing 8, 2 lamp magnetic ballast lighting with electronic ballast and t8 lamps phish1985 General Electrical Discussion 4 03-02-2009 02:57 PM
overheating ballast subelect General Electrical Discussion 4 12-16-2008 01:08 PM
Ballast jfwfmt Vintage Electrical 0 09-12-2008 10:09 PM
Electrician Talk © 2006 - 2010 The Building Network LLC
