Old 08-05-2007, 07:47 AM   #1
JohnJ0906's Avatar
Default ballast with wrong lamps
Yes, I know I should check the label 1st!
I have a 4-tube, 2 ballast T-8 fixture. When I changed the lamps, I replaced them with what was installed (T-12) without checking the label. It was just a few months ago, and when they burned out again so fast, I went to check it, and saw the label "T-8 lamps only" It's what I get for trusting the person before me, I know.
The question is, would this damage the ballasts? Should I replace them up front, or just re-lamp properly, and see what happens?
John from Baltimore
"One day at a Time"
Old 08-05-2007, 10:01 AM   #2
Of all the T8 ballasts that I've run across that have had T12's in them, the lamps are normally fine and the ballast is toast. For that reason, when I convert a fixture (which is what I normally do as T12 ballasts fail), I write on the ballast cover "T8 lamps only", and I warn the owner. In my experience, installing T12 lamps in a T8 fixture almost guarantees that the ballast will die. Your results may vary, but those are mine.
Is it wrong or right alvarez4563 Vintage Electrical 11 03-06-2009 02:26 AM
Ballast jfwfmt Vintage Electrical 0 09-12-2008 10:09 PM
UK wiring standards for Singapore (portable lamps) lesleyanton@mac.com Lighting Design 0 08-13-2008 05:25 PM
Wrong Ballast? Cheap Noob Lighting Design 3 06-25-2008 04:36 PM
Spot lamps wesser General Electrical Discussion 1 02-14-2007 11:33 AM
