Basic Kitchen Rewire Your Method - Electrician Talk - Professional Electrical Contractors Forum
Old 01-22-2011, 04:20 PM   #1
Rewards Points: 2,050
Default Basic Kitchen Rewire Your Method
Just curious what everyones design would be to do a basic kitchen rewire. I don't have any particular method and since I got out of new construction never worried about efficiency too much.
Refridgerator (6.2 amps), Disposal (5.6 amps), undercabinet lighting, overhead cans (4),
Dishwasher (7.1 amps)(not a 10k one, normal one), 2 countertop receptacles, microwave (1,800 Watt on counter).
This one is a 4 family with a distance of 50ft to 1st floor kitchens and 60ft to 2nd floor ones. I'm curious to see who uses more mwc's and who doesnt.
How would you do it???
Cletis
Assuming this of course
In no case shall the load exceed the branch-circuit ampere rating. An individual branch circuit shall be permitted to supply any load for which it is rated. A branch circuit supplying two or more outlets or receptacles shall supply only the loads specified according to its size as specified in 210.23(A) through (D) and as summarized in 210.24 and Table 210.24.
The requirements of 210.23 are often misunderstood. An individual (single-outlet) branch circuit can supply any load within its rating. On the other side, the load, of course, cannot be greater than the branch-circuit rating.
(A) 15- and 20-Ampere Branch Circuits. A 15- or 20-ampere branch circuit shall be permitted to supply lighting units or other utilization equipment, or a combination of both, and shall comply with 210.23(A)(1) and (A)(2).
Exception: The small appliance branch circuits, laundry branch circuits, and bathroom branch circuits required in a dwelling unit(s) by 210.11(C)(1), (2), and (3) shall supply only the receptacle outlets specified in that section.
Section 210.23(A) permits a 15- or 20-ampere branch circuit for lighting to also supply utilization equipment fastened in place, such as an air conditioner. The equipment load must not exceed 50 percent of the branch-circuit ampere rating (7.5 amperes on a 15-ampere circuit and 10 amperes on a 20-ampere circuit). However, according to 210.52(B), such fastened-in-place equipment is not permitted on the small-appliance branch circuits required in the kitchen, dining room, and so on.
(1) Cord-and-Plug-Connected Equipment. The rating of any one cord-and-plug-connected utilization equipment shall not exceed 80 percent of the branch-circuit ampere rating.
(2) Utilization Equipment Fastened in Place. The total rating of utilization equipment fastened in place, other than luminaires (lighting fixtures), shall not exceed 50 percent of the branch-circuit ampere rating where lighting units, cord-and-plug-connected utilization equipment not fastened in place, or both, are also supplied.
Old 01-22-2011, 05:35 PM   #2
That Guy
Mr. Sparkle's Avatar
Rewards Points: 2,002
14/3, 14/2 and a 12/3
Old 01-22-2011, 05:38 PM   #3
Rewards Points: 2,000
Send a message via Yahoo to doubleoh7
I don't believe in MWBC's.
doubleoh7 is offline   Reply With Quote
The Following User Says Thank You to doubleoh7 For This Useful Post:
leland (01-22-2011)
Old 01-22-2011, 05:41 PM   #4
That Guy
Oh, they are very, very real.
The Following 3 Users Say Thank You to Mr. Sparkle For This Useful Post:
erics37 (01-23-2011), jwjrw (01-22-2011), randas (01-22-2011)
Old 01-22-2011, 05:41 PM   #5
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
14/3 micro and DW, 14/3 refrig and lighting. reuse existing 12 circuits for countertop. I like small 14 romex.
Old 01-22-2011, 05:42 PM   #6
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Your'e scaring me , sound like the windbag jerkoff Hampden.
Old 01-22-2011, 05:44 PM   #7
I just don't believe in them.
Old 01-22-2011, 05:48 PM   #8
I own stock in FotoMat!
Rewards Points: 6,520
I rewire an existing kitchen the same as I wire a new kitchen. It just takes longer and I get dirtier.
BIGRED (01-22-2011)
Old 01-22-2011, 05:54 PM   #9
That Guy
Why a 15A ckt for micro? It's on the countertop, put it on the SABC.
Why put the fridge on it's own ckt? Put it on with the SABC that isn't feeding the micro.
I was also assuming none of the existing feeds were being reused.
Old 01-22-2011, 06:11 PM   #10
Jesus Scott
electricmanscott's Avatar
Rewards Points: 232
Want us to show you some pictures.
Life is hard
Old 01-22-2011, 06:20 PM   #11
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I do alot of custom built in units, they mount underneath the countertop in the cabinetry.
Old 01-22-2011, 06:36 PM   #12
That Guy
In that situation I'd do what you do but in the OP he said its gonna be on the counter.
Old 01-22-2011, 07:02 PM   #13
Rewards Points: 2,012
Same, maybe for the bedroom ckts,outside, but NEVER for a kitchen.
JMO-
Old 01-22-2011, 07:18 PM   #14
That Guy
I really can't grasp the reason some guys disdain MWBC's.
If anybody is dumb enough to lift the neutral of one while it is live they should not have been touching the electrical system in the first place.
Put in on a breaker with a handle tie and be done with it.
The Following 2 Users Say Thank You to Mr. Sparkle For This Useful Post:
Old 01-22-2011, 07:41 PM   #15
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
I always run a 12/3 HR and 12/3 between DEEP boxes with a GFI in every box.. none of that feed through stuff..
BIGRED (01-22-2011)
Old 01-22-2011, 07:48 PM   #16
I'd like to take the guys that feed outside receptacles from a GFCI receptacle somewhere in the house and lock them in a portable toilet, then set it on fire.
The Following 4 Users Say Thank You to doubleoh7 For This Useful Post:
administr8tor (01-24-2011), B4T (01-22-2011), JohnR (01-23-2011), randas (01-22-2011)
Old 01-22-2011, 07:51 PM   #17
B4T
B4T's Avatar
They will run (100) ft. of wire to save on a $10.00 GFI..
Old 01-22-2011, 08:03 PM   #18
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
It was a different story years back when 12/2 and 14/2 cost under $70per 1000'. I used to run GFI circuits from the panel GFI for outside,basement and bathroom outlets.
Old 01-22-2011, 08:06 PM   #19
Why skimp? Its a remodel so this is when you fix all the stuff left from the builder.
Mr Rewire is offline   Reply With Quote
Old 01-22-2011, 08:07 PM   #20
What method do you use.. B4T General Electrical Discussion 30 10-30-2010 12:25 AM
rewire psd7.3 Services and Service Equipment 20 07-07-2010 07:53 PM
New name for Rewire? Bob Badger Off Topic (Non Trade) 5 11-22-2009 08:51 AM
Rewire fun randomkiller General Electrical Discussion 2 12-22-2007 08:19 PM
