07-12-2012, 02:19 AM
Battery Powered Peltier (Electrothermal) Cooler?
I'm currently working on a project and need to power a Peltier (electrothermal) cooler. Is there any way i can get cold temperatures with a battery?I've provided a link to the component, they are around 12V and 77W and about 6A.
http://www.amazon.com/TEC1-12705-The...m/B002UQKEU8/2
is there any electrical circuitry i could use off a basic battery or any way to power one of these? I need some cool temperatures on the cool side of the Peltier chip to cool some water, I'll have a heatsink and fan attached to the hot side to increase efficiency.
Thanks~
07-12-2012, 11:51 AM
For that amount of power you will need to use a car battery. Otherwise, just find a used PC power supply or laptop power supply and run it off that. You don't need any special electrical circuitry to power a peltier cooler unless you want to limit the temperature change. In this case you would use a current limiting device, but that is optional. Sounds like the rest of your setup should work.
Chris
Wrench head, knuckle head, farmer.
07-12-2012, 12:07 PM
Lurker...
Thanks~
Why not just use a straight up Liquid Cooling System for a CPU? I am not sure how cold you need to get (or how many BTU's you need to remove), but the Peltier modules don't really pull that much heat out for the wattage used. Plus the fact that you are converting to a water system anyway, makes these preconfigured systems all the more attractive. Plus the overall power usage would probably be less for a 120MM muffin fan motor (typically less than 4W).
http://www.directron.com/bxrts2011lc.html
http://subzeropcs.com/
http://www.frozencpu.com/
However, if you are looking to cool something below room temperature (i.e. chill), the Peltier might be your best bet. Here are some systems that you might be able to hack to get in a configuration you need.
http://koolatrononline.stores.yahoo....s-warmers.html
Maybe you use the Peltier in conjuction with the preconfigured liquid cooling system?
A car or marine battery, or scooter battery (lead acid, deep cycle, AGM) would be your best power source for such an application.
Have fun!
Larry
07-13-2012, 02:07 AM
I'm not lookin to cool my laptop with this project. more of a portable self cooler
07-13-2012, 07:13 AM
Lurker...
I am not suggesting that.  I was suggesting that you use it to get rid of the heat from the peltier....
Good luck with just using a peltier....
Larry
07-13-2012, 10:08 AM
1,000,000th Poster
I made a little soft-drink cooler with one of these. Your best bet is just to get a small switching-mode power supply with inherent overload protection. Try Marlin P. Jones Associates. They sell a lot of that stuff cheap.
-John
07-13-2012, 10:31 AM
Those coolers are great for road trips, camping or getting groceries home. Mine drew about 6A at 12VDC and dropped the temp about 30 deg.
It would keep a bag of ice frozen for a couple of days and worked fine off a 120v/12V 8A battery charger at a campsite.
07-13-2012, 03:06 PM
oh my bad haha, Uhm, i would if it wasnt so redundant, using a water cooler to cool my water cooling system :P.. ill throw a heat sink on it and a fan though.
BUT i really need a semi lightweight batter that can last 2-4 hours =/ only needs to get down to around 40 degrees i guess
07-13-2012, 03:55 PM
Lurker...
Ditch the Thermoelectric cooling. It won't work for your application.
Build a heat echanger backpack with a small pump and circulate a glycol solution through a suit of tubing. Fill the backpack with ice and dry-ice.
Use a couple of R/C, high-capacity, Lithium Polymer (LiPo) batteries. Way more power for the weigh than AGM or Wet cell batteries.
Larry
07-13-2012, 04:10 PM
I'm going to circulate my coolant in a suit but i planned to cool it with the TEC chip, that wont work? i feel with such low temps im cooling it would. i need the back to stay small
07-13-2012, 04:31 PM
Lurker...
Do some research and you will see what I am talking about.
http://thermal.ferrotec.com/technolo...ference-guide/
Heat load is your problem. The Human body + exterior thermal conditions = large # of BTU's needed which exceed most TEC capacities...
Larry
The Following User Says Thank You to LJSMITH1 For This Useful Post:
07-13-2012, 04:35 PM
oh yea.. What about if i just have the coolant circulated through a transmission oil cooler radiator with a fan on it? would that help lower my body temp?
07-13-2012, 05:00 PM
Lurker...
I think you can figure it out with all of the information I gave you.
Good Luck!
Larry
07-13-2012, 05:18 PM
Good Luck!
well...im trying.. but no equations ive found sofar really helped yet.
07-13-2012, 10:56 PM
okay the max W a human dissipates during workout is around 900W.
i plugged these numbers in and it looks like a TEC would work. did i do something wrong?
I couldn't quite get anything from the heat sink one...
im trying i swear
Uploaded with ImageShack.us
07-16-2012, 04:27 PM
any help on the above post? :/
07-28-2012, 01:52 AM
#19
wow. before you want to be condescending how about you ask what my full plans/intentions are. I've done all that research as far as if what i want to construct exists. it doesn't. all those vests either need to be put in a freezer or have a large cooling unit that isn't practically carried.
So thanks for the help but not the attitude.
I was only looking into peltier as an alternative to my current design by the way.
07-28-2012, 02:16 AM
#20
You should make an IV kit that will tap into a vein and an artery, and circulate the human blood through a cooling tower worn on the head, like a stovepipe hat.
The Following 2 Users Say Thank You to MDShunk For This Useful Post:
