Old 11-03-2009, 07:30 PM   #1
Default The best PhotoBucket public images!
JohnJ0906
Thanks John for all of the great pictures you post!
Joe Tedesco is offline   Reply With Quote
Old 11-03-2009, 07:34 PM   #2
#6 copper fan
Magnettica's Avatar
Here's my photobucket page: http://s271.photobucket.com/albums/j...lectricianron/
classicelectriconline.com
Old 11-03-2009, 07:50 PM   #3
DJFVT
John's Avatar
Here's a couple of freebes Joe.
Attachment 2123
Attachment 2125
Attachment 2127
Attachment 2128
Carry On!
Old 11-03-2009, 07:54 PM   #4
EDM
EDM's Avatar
Attachment 2125
Carry On!
What's wrong with an MC From-To?
EDM is offline   Reply With Quote
Old 11-03-2009, 07:56 PM   #5
Rat Bastard
NolaTigaBait's Avatar
Something about the rigid coupling not being listed for that purpose or some crap, i think.
Old 11-03-2009, 08:01 PM   #6
shocked_sparky's Avatar
that "conductor tap" is unbelievable
shocked_sparky is offline   Reply With Quote
Old 11-03-2009, 08:01 PM   #7
DJFVT
John's Avatar
Joe will know..............
Old 11-03-2009, 08:19 PM   #8
See the NECA Standard identified in the NEC in Section 110.12 where it makes it clear that the methods used with various fittings are not listed for that purpose!
Go to www.ul.com and ask the UL Engineers, I won that argument long ago!
PS: Question: Joe why do you underline the word Section?
Answer: Because that's is the correct way to identify the rule in the NEC when not just using the numbers. Use of the word Article 110.12 shows the lack of understanding of the NFPA NEC Manual of Style.
If you don't believe me call the NFPA Electrical Department and get it from them!
Old 11-03-2009, 09:04 PM   #9
OMG that last pic ..lol screw into a phase and tapped...I PRAY that wasn't done by an electrician
All_amped_up is offline   Reply With Quote
Old 11-03-2009, 09:52 PM   #10
na just a handyman!
beartp515 is offline   Reply With Quote
Old 11-03-2009, 09:59 PM   #11
Briancraig81's Avatar
I think the tops the floating soap bottle This is the craziest pic relating to the trade that I've ever seen.
Briancraig81 is offline   Reply With Quote
Old 11-04-2009, 12:21 AM   #12
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
Answer: Because that's is the correct why to identify the rule in the NEC when not just using the numbers. Use of the word Article 110.12 shows the lack of understanding of the NFPA NEC Manual of Style.
I think you mean: way
~Matt
Old 11-04-2009, 05:28 AM   #13
DJFVT
John's Avatar
Nope worse ....DIY's. The tap was for a buzzer to let the DIY's know when the power came back on. They would turn the main breaker off and back feed the panel with a generator. I fixed it by selling them a generator with a transfer switch............they were getting tired of doing the manual method.
Old 11-04-2009, 05:55 AM   #14
Ratus Maximumus
Bob Badger's Avatar
I think you are full of it or maybe it's just selective memory.
All UL will say is the fittings have not been tested for grounding in that use. Approval is up to the AHJ.
I will continue to use a conduit coupling and various connectors to make change overs.
Bob Badger
Electrical Construction and Maintenance
MA, RI, CT
Old 11-04-2009, 06:17 AM   #15
Talking You are violating 300.15!
You are violating Section 300.15 young man!
"Fittings and connectors shall be used only with the specific wiring methods for which they are designed and listed."
PS: How close is your shop to Leo Martin's school and when are you at your desk there in Norwood?
Old 11-04-2009, 06:45 AM   #16
Ratus Maximumus
Bob Badger's Avatar
Nice to know I am still a young man at 45.
Yes and I use MC cable connectors to connect MC cable to the counduit coupling which is listed to 'couple' from there I use a an EMT connnetor to conect EMT. Everything is being used as listed.
And again, when pressed all UL will say is they have not teted that combination for grounding. It is up to the AHJ to approve or not. So if an AHJ has a hair across there ass they could proably give me a hard time .... but they will not.
From the UL white book, it is regarding modifications to UL equipment but applies here as well.
It is the responsibility of the Authority Having Jurisdiction (AHJ) to determine the acceptability of the modification or if the modifications are significant enough to require one of UL’s Field Engineering Services staff members to evaluate the modified product. UL can assist the AHJ in making this determination
I consider that none of your bussiness and odd that you would even ask.
Bob Badger
MA, RI, CT
Old 11-04-2009, 06:53 AM   #17
Part Time Despot
George Stolz's Avatar
Send a message via AIM to George Stolz Send a message via MSN to George Stolz Send a message via Yahoo to George Stolz
Do you sleep on the side of the bed closest to the door, or the other side?
Just curious...
-George
George Stolz is offline   Reply With Quote
Old 11-04-2009, 06:53 AM   #18
Default You are violationg Section 300.15
You are still violating Section 300.15
The AHJ is wrong for allowing you to violate the simple rule above that makes the installations you describe illegal!
I will make it my point to tell them when I go to their next meeting!
To me you are still a young man!
PS: Check your spelling!
Old 11-04-2009, 07:01 AM   #19
Part Time Despot
It is not a secret where you work!
Joe, could you at least for a moment pretend to respect people's privacy?
-George
Old 11-04-2009, 07:14 AM   #20
Default Web addreess was listed here!
He had his web page listed in his profile here and now it is gone!
Why don't you allow the Photoshop images of yours to be viewed?
public house installation b.carroll.electrical UK Electrical Forum 3 04-15-2008 05:36 PM
Sharing images? brian john Off Topic 11 07-07-2007 06:08 PM
Sharing Images on Photobucket Joe Tedesco Off Topic 1 07-03-2007 08:05 AM
Area Inspectors vs. Public Utility Community Planners a.b.e. General Electrical Discussion 7 04-07-2007 10:45 PM
