Old 06-23-2010, 01:56 PM   #1
Send a message via Yahoo to doubleoh7
Default Bidding commercial first time
I am bidding my first commercial job. The commercial work that I have done since starting my business 15 months ago has been smaller stuff, T & M. Now I have an opportunity to bid an small eye clinic - optomotrist office.
Bidding residential is pretty much a piece of cake IMO. I have a price per opening established that works for me. I allow 45-50 minutes per opening on most openings. Does anyone use a price per opening for commercial. Or, do you just break the job down into components and assign a time value to each then do your take off for material?
Advice please.
Thank You in advance.
doubleoh7 is offline   Reply With Quote
Old 06-23-2010, 02:02 PM   #2
Fried Bologna um um good!
jwjrw's Avatar
First I figure all the material.
Next I try to figure labor. I usually figure labor room by room.
Then hvac systems, fire alarm, telephone etc. It may not be the best way but it works for me.
Old 06-23-2010, 02:07 PM   #3
Electric Al
oldtimer's Avatar
Advice please.
My advice is to check the plans and see what is required. Then break it down, to do your take-off. I do not think it is a good idea to estimate it by the outlet! The G.C. should be able to assist you.
Old 06-23-2010, 02:08 PM   #4
Thanks
The material is a lot easier to figure than the labor, obviously. When you figure each room do you assign a time for each piece of emt?
Old 06-23-2010, 02:10 PM   #5
jwjrw's Avatar
Thanks
Thats is the hard part for sure. I try to picture in my mind each task required and how long it should take. Notice I said "should" take. I always add in a little more as things don't ever go smooth for me.
Old 06-23-2010, 02:13 PM   #6
Electric Al
oldtimer's Avatar
Dive in !! Get your feet wet! BEST OF LUCK.
The Following User Says Thank You to oldtimer For This Useful Post:
doubleoh7 (06-23-2010)
Old 06-23-2010, 02:32 PM   #7
Yes, I am just going to have to take some time to do this. I guess I was sort of looking for a shortcut. That could be dangerous! I will break it into room size chunks and then go opening by opening figuring material and assign a time value to each piece.
Old 06-23-2010, 02:42 PM   #8
jwjrw's Avatar
Good luck. I don't care how many times I go over a set of plans I miss something. I'm lucky to have another set of eyes to make sure I got everything. Even then things come up on site that can make or break you if you didn't estimate enough.
Old 06-23-2010, 02:51 PM   #9
976-EVIL
mcclary's electrical's Avatar
[quote=doubleoh7;245715]Thanks
The material is a lot easier to figure than the labor, obviously. When you figure each room do you assign a time for each piece of emt?[/quote]
In case you're curious:
My software allows 4.2 craft hrs for 100' of empty 1/2" EMT,,,,,,$54 material
4.8 craft hours for 100' 1/2" emt w/ pull line,,,,$57 material
6.2 craft hours for 100' 1/2" w/ (3) 12's,,,,,,$95 material
that w/ 2 box connectors, 10 straps, 9 couplings
pm me your details I'll give you a ballpark
Old 06-23-2010, 03:03 PM   #10
Chief Electron Relocator
If this is being done in a strip mall, check to see if the owner (landlord) is providing anything. Some provide a furnace & AC already, so you don't need to bid that. Sometimes the panel is already set in place and energized, sometimes you need to complete the feeder and set a panel. Sometimes you need to come from the meter stack with your own raceway all the way.
Sometimes the landlord will not allow a tenant to do anything with the fire alarm and sprinkler system... they will require their own subs to do that so it prevents any warranty & liability issues.
Temp lighting and temp power may or may not be provided as well.
Also inquire about the schedule. If they want if done by Oct. 1, that's fine. But the price goes up if they want to open July 5th.
Old 06-23-2010, 03:08 PM   #11
No strip mall. 29' x 62' building - new construction.
Old 06-23-2010, 03:10 PM   #12
Then I'd check out things like local ordinances for lot lighting, signs, etc. I've run across plans sent out for bid purposes that have never been submitted for plan review by the AHJ.
Old 06-23-2010, 03:34 PM   #13
Exasperating Member
JohnR's Avatar
Not saying you don't know this already, but make sure you figure for hospital grade MC in any rooms that a doctor might be dealing with a patient.
Don't matter if it is a couch in a phyc's office. up to 7-1/2' has to be hospital grade. lightswitches and outlets.
I know a guy who forgot this and got bit.
Didn't hear if it was the doctor or a patient that bit him though.
JohnR is online now   Reply With Quote
Old 06-23-2010, 03:37 PM   #14
Good point. I don't think that applies here. I said eye clinic, but what I really meant is optomotrists office. The kind of place that you go for contacts and glasses.
Old 06-23-2010, 03:42 PM   #15
Exasperating Member
JohnR's Avatar
Well I did an Optometrist/Ophthalmologist office and anyplace there was a seat for a guest/patient to receive care, I had to put in the HG wire.
Stupid, I know but it didn't matter if it was just the area where glasses were fitted. Had to have it.
Old 06-23-2010, 05:56 PM   #16
I use a spreadsheet. Item 1 being distribution. Then that is broken up into smaller sections. Install panel 1, feeders for panel 1, terminate panel 1, etc. Then Outlets, broken up into sections. Home runs, rough, finish, etc. Then Switching. Home runs, rough, finish, etc., Lighting. Install, lamps, T24, emergency, etc. HVAC, Plumbing, etc. Don't forget Supervisory. This category has everything else. material acquisition, job set up and removal, demo, temp power, meeting, etc. This is by no means complete. The way I've set mine up, all those tasks are in my vertical column. I can then use the horizontal columns for dates and keep daily track of hours used compared to hours bid.
Read 517 though and through to see where and how it applies to your situation.
Old 06-23-2010, 06:15 PM   #17
Thanks
Most of that type of work here is MC
The only EMT is phone stubs 3/4
Wingnut is offline   Reply With Quote
Old 06-23-2010, 06:44 PM   #18
Ring and string is even faster and cheaper.
Old 06-23-2010, 07:48 PM   #19
Yea, I don't think for the office area it applies. But if there is an exam room, I believe you do need hospital grade material.
Mrtofu82 is offline   Reply With Quote
Old 06-23-2010, 07:58 PM   #20
Senior Estimator
chiefestimator's Avatar
Residential and commercial estimating are very different. Some of my career has been in residential, but most has been in commercial/industrial.
The method you use (by the hole, or unit pricing), is a very popular method for residential estimating. It does not work for commercial estimating for a number of reasons, including interference from other trades, lack of coordination by the GC, and the configuration of the projects to name a few.
Most comercial estimates are done the longhand method, where all of the work represented on the plans is counted and measured. Light fixtures, outlets, switches, panels, disconnects and generators are the types of things that are counted. Branch (1/2" thru 1") and feeders (1-1/4" thru 6") are measured. In some parts of the country (mostly the east) branch is averaged, such as 20' per receptacle. This entire process is called the takeoff.
If you are doing this by hand, the next step is to "explode" the counts. and list them on a pricing sheet. For instance, (10) 2 gang switches equal (10) boxes, (10) rings, (20) switches and (10) plates. Some people add some miscellaneous things like grounding pigtails and wirenuts.
When you are finished each line on your price sheet needs to be priced, labored, extended and totaled. The totals get transfered to a "Recap" where quotes, subs, rentals, misc and markups are added. As you can see, it is quite a bit more involved than residential.
I tried to attach a sample Excel spreadsheet, but was advised it was an illegal file type. If you are interested, contact me privately and I can email it to you.
Of course, there are quite a few software packages to help with the process. As someone new to commercial estimating, I would not advise spending money on the big dollar packages. If you want to try some out, there are a few based on subscriptions, so you can try them out for a few months to see if they work for you.
Another thing about commercial work is specifications. Sometimes they are on the plans, and other times they are in a seperate book. Ignore them at you own risk. Because of the current economic conditions, many contractors are ignoring the specs and bidding on the cheapest materials and methods. Some get away with, but many do not. If you are going to ignore the specs, write qualifications into your proposal, such as "This project will be wired with MC rather than EMT as specified".
Lastly, commercial estimating can get complex. Be carefull as you get into larger projects.
OK, I'm done with this book. Good luck
chiefestimator is offline   Reply With Quote
Bidding on commercial projects Absolutetruthz Business, Marketing, and Sales 4 06-07-2011 10:04 PM
Long time viewer 1st time poster Brechi98 Introductions 8 05-29-2010 04:00 PM
Long time commercial Jman new to resi. Some questions dr electron Residential Electrical Forum 22 05-07-2010 08:59 AM
Long time listener - first time caller PJSkiboy Introductions 14 01-27-2010 10:08 PM
