Old 06-07-2008, 01:29 PM   #1
Default Bolted Pressure Switch
What it should look like
Not sure what happened here, but the call was for a switch that would not open...
Water and electricity never mix
Old 06-07-2008, 01:29 PM   #2
I forgot to order fuses? and who needs an operator.
Who needs ground fault protection
Old 06-07-2008, 01:30 PM   #3
What happened to posting pics directly into the post?
Old 06-08-2008, 12:02 AM   #4
TheRick's Avatar
Water and electricity mix just fine...the results however are often undesireable.
Rick Boudreau
Tal Afar, Iraq
Old 06-08-2008, 04:49 AM   #5
DJFVT
John's Avatar
What is this and was It the problem? It looks like an insulated tie bar for operating the switches and it looks broken.
Attachment 539
Old 06-08-2008, 06:21 PM   #6
That ties the movable contacts to the CBC mechanism, and yes it is broken in the IR picture you can see a thermal issue as the contacts are not properly closed.
Old 06-09-2008, 02:17 AM   #7
"Euro" electrician
The damage caused by operator error ??
By not following the correct prodcure to order to disconnect the device in correct format.
Merci,Marc
Old 06-09-2008, 06:42 AM   #8
Most issues I see with bolted pressure switches are operator error. In this case I believe this is a defect with the cross arm. The customer tried to open the switch and it locked up.
Old 06-09-2008, 10:15 AM   #9
"A" inside wireman
randomkiller's Avatar
Just from a quick look the resin bar seems light for the amount of leverage it needs, the point of attachment for the arm should have been beefier.
"One Nation Under God"
Old 06-09-2008, 09:09 PM   #10
RK: I have serviced literally 1000's of these switches and installed 100's, this was the first time I have seen this happen. What you can't see is the metal plate across the top where the operator arm attaches to the cross arm.
Looking for switch Hefty General Electrical Discussion 2 10-21-2008 11:15 PM
Replace a 2 way switch by time lag switch emleray General Electrical Discussion 4 09-12-2008 04:18 PM
pressure switch kawaikfx400 General Electrical Discussion 6 08-02-2008 04:53 PM
Hot 3 way switch subelect General Electrical Discussion 21 07-20-2008 09:46 AM
Bolted pressure Switch brian john General Electrical Discussion 5 07-11-2007 09:18 PM
