Bonding of above ground pool shell - Electrician Talk - Professional Electrical Contractors Forum
Old 05-20-2011, 10:51 AM   #1
Rewards Points: 504
Default Bonding of above ground pool shell
Am I interpreting the code correctly saying that the shell must be bonded at 4 evenly spaced locations around the contour of pool? And having trouble making sense of how far from the outside walls the conductor needs to be? And at least 4 inches below grade.
Gamit is offline   Reply With Quote
Old 05-20-2011, 12:33 PM   #2
Rewards Points: 504
Basically what I am asking is the alternative method what I should be using?
Old 05-20-2011, 01:31 PM   #3
Rewards Points: 1,006
Perimeter bonding is 18 to 24in. from the inside wall of the pool, within or under the perimeter surface, 4 to 6in below the subgrade.
Don't forget the rest of the bonding requirements...poolwater, metal w/in 5ft, pump, etc.
__________
Was born in HACKensack, NJ
CraigV is offline   Reply With Quote
Old 05-20-2011, 01:44 PM   #4
Rewards Points: 504
Yea understand everything else but if you didn't use alternative for above ground what's the non-alternative?
Old 05-20-2011, 01:54 PM   #5
What code cycle are you meeting?
__________
Old 05-20-2011, 04:11 PM   #6
Rewards Points: 504
I'm sorry not sure what you are referring to?
Old 05-20-2011, 05:09 PM   #7
Rewards Points: 2,000
I'm sorry what are YOU referring to?
Bond the water,hit the pump,hit 4 spots of the pool along the way..
Just like the other guy posted .
What alternative are you talking about?
robnj772 is offline   Reply With Quote
Old 05-20-2011, 05:18 PM   #8
Rewards Points: 504
I didn't understand the term code cycle ? And they call this the alternative method., alternative to what? Was what I was referring to.
Old 05-20-2011, 05:23 PM   #9
Jesus Scott
electricmanscott's Avatar
Rewards Points: 232
What the hell are you talking about?????
Life is hard
The Following 2 Users Say Thank You to electricmanscott For This Useful Post:
Magnettica (05-20-2011), robnj772 (05-20-2011)
Old 05-20-2011, 05:56 PM   #10
i'll try to help you out
He asked you what code cycle you were on, What year NEC code is your state using your in NJ so we are still using 2008
Now as for this "alternative"method, There is only one way to bond a pool, The code does not give you different options. The only varying option you have is how to bond the water, I prefer the bondsafe 680 plate for the skimmer but you can also get the water bonder fitting for the pool pump hose.
Old 05-20-2011, 05:59 PM   #11
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
And you can read more by clicking here
Replies based on NEC 2014
Old 05-20-2011, 08:45 PM   #12
Rewards Points: 504
Yes thanks for understanding
Michigan: Pool bonding Greenblinker General Electrical Discussion 0 04-05-2011 08:37 PM
Pool BOnding Mark Turner General Electrical Discussion 4 12-28-2010 05:09 PM
Pool Bonding dawgs NEC Code Forum 8 07-20-2009 07:30 AM
Pool Bonding rebel34 NEC Code Forum 21 08-16-2008 09:32 PM
Pool Bonding preacher NEC Code Forum 15 03-29-2008 11:10 AM
