Old 03-08-2010, 03:12 PM   #1
Default Box Offset
What is the proper way to bend a box offset in conduit? I've read that its roughly two 10 degree bends, but what is the spacing between bends? I usually just sort of eye ball it and tweak it until its right but I'd like to be more accurate and consistent.
Thanks
Conduit Phil is offline   Reply With Quote
Old 03-08-2010, 03:17 PM   #2
jw0445's Avatar
If your going to do this on a regular basis or over many years buy yourself both 1/2" and a 3/4" offset benders. They will pay for themselves many times over. You put your conduit in the bender, press the lever down, and presto, perfect offsets every time. They run from $200 to $300 each new. Check ebay for some deals.
The Following User Says Thank You to jw0445 For This Useful Post:
french connection!! (02-19-2012)
Old 03-08-2010, 03:24 PM   #3
Cam
Best way to do this is to practice. Use scrape pieces of conduit with a box with a connector on it. Bend with bender standing up. Try to keep conduit straight to prevent dog leg when you turn it. Try small angles at at time. Youre get the hang of it.
Cam is offline   Reply With Quote
Old 03-08-2010, 03:25 PM   #4
Can't say as I've ever measured any offsets. I just eye it up. If I'm doing more than a few, I just use the offsetter tool.
The Following 2 Users Say Thank You to MDShunk For This Useful Post:
John Valdes (02-20-2012), sparky970 (10-03-2012)
Old 03-08-2010, 03:25 PM   #5
PGW Professional
Magnettica's Avatar
Thanks
I pretty much eyeball it too. But obviously for an offset larger than just for a box I use 30º bends and use the multiplier of 2 so an 8" offset bend would make the bending marks 16" apart.
Old 03-08-2010, 03:36 PM   #6
That's it.
Old 03-08-2010, 03:40 PM   #7
PDX-SPARKY's Avatar
I use what is referred to as Kentucky Windage Works like a charm.
What size pipe?
If its 1/2" or 3/4" I just eye ball it, if it is 1" or larger then you can get into some calculations if applicable.
Usually if it is smaller pipe and I bend the Box Offset my first bend is a fingers width away from the end of the pipe (so I know where my first bend started and it doesn't pinch the end of the pipe), second bend is as close as I can get to the first bend radius or within 6" of the first bend.
I was taught when you make an offset that it shouldn't be a drastic change but more of a smooth transition to the box for easier pulling.
PDX-SPARKY is offline   Reply With Quote
Old 03-08-2010, 03:40 PM   #8
For many,many box offsets I second the offset kicker.
slickvic277 is offline   Reply With Quote
Old 03-08-2010, 03:41 PM   #9
Senior Troll
wishmaster68's Avatar
amazon has them 1/2 inch for 180 and 3/4 for 260
wishmaster68 is offline   Reply With Quote
Old 03-08-2010, 03:55 PM   #10
If you look at the table on page 9 of http://www.mikeholt.com/documents/fr...ndRaceways.pdf
it says the distance between bends for a 10 degree bend is 2-7/8" .. Well someone mentioned on another thread that the distance between bends for a box offset is approximately 3". I tried using 3" and it was a little bit off, so I'm not sure if that 1/8" was the deciding factor or not.
I'm curious as to what degree and distance between bends that Greenlee bender uses.
Old 03-08-2010, 03:58 PM   #11
I have a couple of these I picked up at a garage sale somewhere.
Never used one.
Box offsets are over rated IMO but if I feel he need to use one, I just eyeball it like everyone else.
Old 03-08-2010, 04:01 PM   #12
Hack.
Old 03-08-2010, 04:12 PM   #13
Look at Newguy jumping right in there ^
Old 03-08-2010, 04:14 PM   #14
Hack.
Hackity hack this is what i use But i dont use emt often in residential. Only in the basement i do and when i do i buy these.
pawirenut is offline   Reply With Quote
Old 03-08-2010, 04:19 PM   #15
Ha, I've used those before but they cost more than a stick of conduit itself!
The Following User Says Thank You to Conduit Phil For This Useful Post:
Old 03-08-2010, 04:23 PM   #16
I know i only use them if im running washer and dry receps down a wall from the joists in a basement.
Old 03-08-2010, 04:28 PM   #17
PGW Professional
Magnettica's Avatar
Nothing wrong with using those box offset connectors.
Old 03-08-2010, 04:50 PM   #18
Other than it's hack, and you used a 2-dollar fitting where you could have made a bend in 30-seconds for free.
The Following 3 Users Say Thank You to MDShunk For This Useful Post:
bruce6670 (10-03-2012), John Valdes (02-20-2012), sparky970 (10-03-2012)
Old 03-08-2010, 04:57 PM   #19
Ax grinder
raider1's Avatar
Agreed, a box offset is not rocket science and takes very little time to bend.
Chris
Old 03-08-2010, 05:05 PM   #20
Most certainly nothing hack about it. Please explain why exactly it's a hack way? Now if i used 100 of them that is definitley a hack but the most i use is 2 for a washer and dryer recep like i said. If i'm mounting a lot of boxes i will bend them.
Offset Nipples Flash NEC Code Forum 22 07-19-2009 06:13 PM
Need help making a rolling offset steadypimpin General Electrical Discussion 38 06-09-2009 07:07 PM
