Breaker Interchange - Electrician Talk - Professional Electrical Contractors Forum
Old 05-31-2011, 11:38 PM   #1
Rewards Points: 2,000
Send a message via Yahoo to doubleoh7
Default Breaker Interchange
Breaker interchangeability - I really need to study up on the stuff. Today, on a service call, I added a 20 amp Siemens S.P. breaker to a Murray panel. Is that a listed interchange?
doubleoh7 is offline   Reply With Quote
Old 05-31-2011, 11:40 PM   #2
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Siemens and Murray are one of the same.....Murray is Siemens cheap knock off brand.
Old 05-31-2011, 11:41 PM   #3
Rewards Points: 2,002
Well technically, Siemens and Murray are not interchangeable despite being absolutely identical. I still interchange them anyway.
Now, if we are talking about mixing and matching other brands, that is just plain hack.
The Following User Says Thank You to user4818 For This Useful Post:
220/221 (06-01-2011)
Old 05-31-2011, 11:42 PM   #4
The only difference on the breakers is the name. The panels are slightly different but still share many of the same features.
Old 05-31-2011, 11:43 PM   #5
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Siemens usually sports a copper bus and bus length neutral bars.
Old 05-31-2011, 11:45 PM   #6
Yeah. And Siemens has the neutral terminals backed out and they are square drive. Murray still uses old fashioned straight blade neutral bar terminals.
Old 05-31-2011, 11:46 PM   #7
I thought they were cousins. I was having second thoughts. I would hate to burn up someone's bussbar. The panel was hackorama,maybe ten years old. I asked the customer, (HO's son) who wired the home? He said, well the guys that did it weren't really electricians. I laughed out loud and said "yeah, I can tell".
Old 06-01-2011, 12:03 AM   #8
Rewards Points: 504
There's a few lists out there. A quick Google search brought up this list.
Its a PDF file by the way.
Mike_586 is offline   Reply With Quote
Old 06-01-2011, 12:05 AM   #9
I need to print that off and keep it in the trailer.
Old 06-01-2011, 12:21 AM   #10
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Yes they are..
Murray and Siemens are the same.
Murray = Chevy
Seimens =Cadillac
Old 06-01-2011, 12:23 AM   #11
RIP 1959-2015
HARRY304E's Avatar
Murray has not use the straight blade neutral bar terminals for a long time now..
Old 06-01-2011, 12:32 AM   #12
Originally Posted by HARRY304E View Post
Yes they are..
Murray = Chevy
Seimens =Cadillac
So if they are the same, why is one a Chevy and one a Cadillac?
Old 06-01-2011, 12:36 AM   #13
RIP 1959-2015
HARRY304E's Avatar
Top Shelf
Bottom Shelf....
Old 06-01-2011, 12:40 AM   #14
Harry --------->
Old 06-01-2011, 12:58 AM   #15
Rewards Points: 3,855
Every once in a while you'll get Seimens breakers in Murray packages, and vice-versa. More and more, I favor carrying a classified-replacement breaker on the truck (generally from CH), rather than carrying so many odd brands for service calls. If I'm doing a project where I KNOW I'll be using a bunch of a certain brand, I'll buy that brand particular for that panel. For service work, I just use a type CL breaker, unless I happen to have the right one kicking around on the truck.
Old 06-01-2011, 03:50 AM   #16
RIP 1959-2015
HARRY304E's Avatar
Harry --------->
Too comlpicated for you ehh pete..
Old 06-01-2011, 08:44 AM   #17
Rewards Points: 638
Like Marc said, I only carry three types of breaker generally. Cutler Hammer CH, Square D QO, and Cutler Hammer CL.
If I'm doing a remodel or new work I'll get the brand breakers, but there is no reason to not have a case or two of the CL breakers on board.
Old 06-01-2011, 09:32 AM   #18
Not quite. You don't make any sense. The breakers are identical and the panels nearly identical. I don't see how one is Cadillac and one is a Chevy. They are both a Chevy.
Old 06-01-2011, 09:34 AM   #19
I carry most Homeline since that is my main brand, followed by Cutler Hammer (since I run into a lot of Bryant, Challenger, Westinghouse, T&B and C-H panels) as well as a few boxes of mixed Siemens/Murray stuff. I really should mix it up with some CL though.
Old 06-01-2011, 09:53 AM   #20
Electric Al
oldtimer's Avatar
Rewards Points: 2,306
I totally agree with you. But Little Dog knows best!!
Steven Wright
40/60 breaker wirenut1110 General Electrical Discussion 23 04-25-2011 10:24 PM
28V interchange sparky723 Tools, Equipment and New Products 1 11-28-2010 01:40 PM
Can I put a breaker box here? den NEC Code Forum 31 11-10-2010 12:13 AM
breaker on, wires have voltage; breaker off, wires have continuity. How can this Be? Weskey General Electrical Discussion 6 10-08-2009 09:47 PM
Hot Breaker Podagrower General Electrical Discussion 42 08-22-2009 12:08 AM
