Old 02-19-2009, 05:34 PM   #1
Wyome
Default broken wire spools
I have just about had a gutfull of those cheap plastic wire spools that #12 and #10 come on now. We have no supply house here so everything gets shipped ups or freight. Open up the boxes and the ends are all cracked or broken off. Can't even look at one and it breaks, never mind dropping it. What a giant pain. y'know? Just about have to have two men now at the wire cart, one to push and one just to keep all that mess under control. Sorry, just had to let it out.
Old 02-19-2009, 05:37 PM   #2
Seen your member
Click here.
This message is hidden because Forgery, JackBoot, LawnGuyLandSparky, milehiwire and user 5941 are on your ignore list.
Old 02-19-2009, 05:40 PM   #3
Click here.
480 YOU DA MAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 02-19-2009, 06:26 PM   #4
electricalperson's Avatar
worst thing an electrician has to do is work with broken spools of THHN
Old 02-19-2009, 06:41 PM   #5
Should have been around when it came in boxes. It could turn ugly quick especially in the hands of an apprentice.
Old 02-19-2009, 06:45 PM   #6
Not Peter D
They should put wire on metal spools again. If it meant an extra dollar or two to the cost, I would gladly pay it to not have to deal with the aggravation of broken spools.
Old 02-19-2009, 06:56 PM   #7
JohnJ0906's Avatar
If that is the worst thing you deal with on the job, you are very fortunate!
I loathe those plastic spools myself, but they are far down the list of bad things I deal with.
John from Baltimore
"One day at a Time"
Old 02-19-2009, 07:16 PM   #8
I havent seen the plastic spools in a long time. The few I have seen were roll ends that have traveled from other jobs.
Might just be one manufacturer?
That said, the rolls with the wood ends, our #6 has it, almost always break, and 480 that link is perfect!
Jeff000 is offline   Reply With Quote
Old 02-19-2009, 07:18 PM   #9
i bet you could make one
Old 02-19-2009, 07:21 PM   #10
Not Peter D
What brands of wire do you have in Canada? Is any of it imported from the United States?
I'm guessing Canadian wire manufacturers still use metal spools.
Old 02-19-2009, 07:22 PM   #11
Seen your member
Might just be one manufacturer? ......!
Just the opposite for me. It's always plastic. I still have some old metal spools the oddball colors (purple, pink) that are still rattling around from job to job.
Old 02-19-2009, 08:07 PM   #12
Nuff Said.
480- When do you find time to work? finding all these items.
Must not have a Bride.
Old 02-19-2009, 08:18 PM   #13
Seen your member
Originally Posted by leland View Post
Nuff Said.
Peter d and I are going to start a single's bar.
Old 02-19-2009, 08:47 PM   #14
Not Peter D
Yup, Sparky's Bar and Grille. I'm planning on being the chef. 480 is going to be the nightly entertainment.
Old 02-19-2009, 08:50 PM   #15
can i be the bartender?
Old 02-19-2009, 08:52 PM   #16
Not Peter D
No, I've instructed the bouncers to not even let you in.
Old 02-19-2009, 08:58 PM   #17
I called every local distributor (8 or 10) I could think of one day a year or two ago begging to get all my wire there if they just could get it on metal spools.
No luck.
volty is offline   Reply With Quote
Old 02-19-2009, 09:00 PM   #18
Designated drinker open?
Old 02-19-2009, 09:15 PM   #19
Seen your member
No, it's already taken........ sorry..........
Old 02-19-2009, 09:59 PM   #20
wire connectors stillirnin General Electrical Discussion 26 05-12-2008 09:52 PM
which wire do you cut rdtcmtt General Electrical Discussion 1 03-25-2008 10:44 PM
Broken lamp base in socket JohnJ0906 General Electrical Discussion 8 03-16-2008 08:59 PM
Broken pvc Bkessler General Electrical Discussion 14 01-26-2008 03:59 AM
low wire JohnJ0906 Linework 10 12-29-2007 01:48 PM
