Bucket truck work - Electrician Talk - Professional Electrical Contractors Forum
Old 12-02-2009, 05:22 PM   #1
Rewards Points: 250
Default Bucket truck work
Just looking for what you guys are getting for using your truck. Just a ball park number. Or do you not charge for the truck you just charge your service call rate?
Sparky480 is offline   Reply With Quote
Old 12-02-2009, 05:29 PM   #2
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
I rented a towable boom lift for (4) hours and that cost me $260.00
Old 12-02-2009, 05:31 PM   #3
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,536
...and I hope you marked that price up as well.
Old 12-02-2009, 05:36 PM   #4
B4T
B4T's Avatar
I had to change a 400w HPS lamp in my backyard on a 30 ft. pole
Old 12-02-2009, 05:44 PM   #5
BuzzKill's Avatar
...I might've just went to big blue and bought a motion light! $260 to do all that, for yourself?
Old 12-02-2009, 05:47 PM   #6
william1978's Avatar
Rewards Points: 2,000
Could you have used a extension ladder? If so you could have bought a extension ladder.
Old 12-02-2009, 05:54 PM   #7
B4T
B4T's Avatar
It is on a (4) ft. long arm.. same as a street light.
I wanted to get 360 degree coverage.
Even with a light bright enough to read a paper, some dirtbag broke into a storage shed to steal tools
They climbed on top of the roof and ripped up the skylight with a claw hammer.
I just happen to walk into the kitchen and see this guy walking across my yard carrying my chainsaw.
I yelled and he dropped everything.. broke the land speed record for 100 yards
Old 12-02-2009, 05:59 PM   #8
BuzzKill's Avatar
Oh snap!
Old 12-02-2009, 06:07 PM   #9
Rewards Points: 81
I use another local electrical contractor with a 65ft Altec bucket truck when needed. He usually charges $55.00hr including labor then we mark that up.
Hope that helps
Bill
Electric Bill is offline   Reply With Quote
Old 12-02-2009, 06:10 PM   #10
Proud Navy Veteran
Greg's Avatar
Rewards Points: 588
$55/hr for the bucket truck plus labor and parts. We have a 65' truck.
Memorial Day: All gave some but some gave all.
Take the time to tell a Veteran Thank You, You owe him/her at least that much. After all Freedom is not Free.
Old 12-02-2009, 06:10 PM   #11
BuzzKill's Avatar
Hope that helps
Bill
does he have a minimum?
Old 12-02-2009, 06:15 PM   #12
Rewards Points: 81
Typically we do a 4hr min. This makes sure to cover his expenses. He is working as a straight sub when we use him. Great guy, 25yrs exp. gets the job done right the first time every time. Works out great for us.
Bill
Old 12-02-2009, 06:49 PM   #13
joebell's Avatar
Rewards Points: 156
Hope that helps
Bill
That seems kinda cheap for a 65' truck. We rent 40+ footersand per day I think it is around $600.00 or more per day.
joebell is offline   Reply With Quote
Old 12-02-2009, 10:37 PM   #14
Rewards Points: 250
Sounds cheap to me. Although how often do you use him? I guess in the long run to keep the rolling billboard moving its not a bad number
Old 12-04-2009, 09:54 AM   #15
Depends on what kink of work your doing and most of all Do you know what your doing. Not a great place to work if you head is not screw on tight. I have been at this for 40 years and you can get what you want if you show people you are the best. Takes alot of time and effort. I get 165.00 per HR. and that is one man rate. Dbl bucket and 2 men you can get 250.00 per HR depending on the job. Most our work is high voltage line work. If your not in the trade It take a lot of time to learn. Fosel
fosel is offline   Reply With Quote
Old 12-04-2009, 10:10 AM   #16
Grimlock's Avatar
Rewards Points: 502
Cost + desired profit.
Add a "base" charge or "starting rate" then go T&M.
Grimlock is offline   Reply With Quote
Old 12-04-2009, 10:41 AM   #17
How you do your book keeping is up to you. I was stating a basic bucket truck rate. I'm sure after all this time we are OK with any code. If you have spent the time in the trenches its time to get what you deserve. I'm very sure if I get a cat out of a tree the charge will be where it needs to be. Could be a code for that?????????????
Old 12-04-2009, 11:21 AM   #18
Grimlock's Avatar
Rewards Points: 502
What code are you referring to? Your post suggests that someone made mention of a code of some sort. Are you referring to a "Formula" that one might use to produce a price? You lost me with the code thing, I don't recall it in the NEC either, they don't even suggest that we should charge for our work....
Old 12-05-2009, 11:22 AM   #19
If your getting someone with a bucket for 55 per Hr, Better check out Insurance. I can't understand how anyone can make ends meet? The maintenance can be very costly as well as insurance. We have a 2 hr min. That helps. You could face a lot of problems if there is an accident. Times are tough but be very careful.
Old 12-06-2009, 04:39 AM   #20
McCaa's Avatar
$95 per hour.
McCaa is offline   Reply With Quote
Buy a bucket truck? All_amped_up Business, Marketing, and Sales 13 03-24-2014 03:44 PM
Wanted - Bucket Truck oldman Off Topic (Non Trade) 20 08-07-2011 04:01 PM
Bucket Truck Accident jfwfmt Workplace Safety 4 12-13-2010 03:19 PM
2001 Ford F550 Bucket Truck Quality_Trucks Tools, Equipment and New Products 9 08-09-2009 09:44 PM
1 ton bucket truck OR van for service work personal Tools, Equipment and New Products 5 02-18-2009 07:04 PM
