BX - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-12-2013, 06:17 PM   #21
motherplucker
chicken steve's Avatar
Rewards Points: 4,302
but....i like red heads! ~CS~
Hippie (02-12-2013)
Old 02-12-2013, 06:35 PM   #22
Rewards Points: 516
For whatever reason I usually spin that bond wire back down the mc and put my connector right over it and let it pinch down on it.
Guess I learned different than all of you?
running dummy is offline   Reply With Quote
Old 02-12-2013, 07:49 PM   #23
Rewards Points: 77
I saw one manufacturer stated that both cutting the bond wire and wrapping it were approved when terminating BX. They even said it could be wrapped under or over the red head. I think it was on here that someone posted that.
akheilman is offline   Reply With Quote
Old 02-12-2013, 08:17 PM   #24
Rewards Points: 2,950
You meant to say "AC"? People are easily confused when we don't use the proper terminology. MC doesn't have the bonding strip. And yes, they are to be wrapped back or cut flush with the jacket, not to be terminated, because it is not a conductor. It is part of the jacket assembly which allows it to be rated as an equipment grounding conductor. Without it, it is just BX cable. The jacket of which is not rated as an equipment ground.
The Following 2 Users Say Thank You to btharmy For This Useful Post:
Celtic (02-13-2013), chicken steve (02-13-2013)
Old 02-12-2013, 11:40 PM   #25
Originally Posted by HARRY304E View Post
You don't need the red head for MC Cable.
I know. But it seems like tradition still dictates their use. I'll use one depending on how easy they are to find at the moment.
Deepwater Horizon is offline   Reply With Quote
Old 02-13-2013, 05:43 AM   #26
Deep Cover's Avatar
Rewards Points: 2,024
I don't use red heads very often anymore. Most of the connectors we use have the red heads built in.
Deep Cover is offline   Reply With Quote
Old 02-13-2013, 07:49 AM   #27
butcher733's Avatar
Rewards Points: 788
What would you use BX for instead of MC? Is it cheaper?
I'll take therapists for $400.
butcher733 is offline   Reply With Quote
Old 02-13-2013, 09:13 AM   #28
Is it still common in some locations to use the term BX? It hasn't been manufactured for years. AC has the bonding strip, MC has the full size ground and BX had neither. That's why it is extinct as the DoDo bird.
Old 02-13-2013, 09:16 AM   #29
Rewards Points: 2,000
You would think it would be cheaper because it doesn't have the extra 250' of wire in it. Not true. Simple economics. Supply vs demand.
Old 02-13-2013, 04:52 PM   #30
butcher733's Avatar
Rewards Points: 788
I've only dealt with MC, aluminum case with insulated ground conductor. Does AC have no ground conductor other than the case with bond wire? Is AC steel cased or aluminum? What are the different applications between them?
Old 02-13-2013, 05:52 PM   #31
Yes, AC has no ground conductor. The jacket in conjunction with the "bonding strip" serve as the egc. You can get both aluminum or steel jacket. Otherwise their applications are pretty much the same.
AC- http://www.southwire.com/products/ArmorliteTypeAC.htm
MC- http://www.southwire.com/products/ArmorliteTypeMC.htm
The Following User Says Thank You to btharmy For This Useful Post:
butcher733 (02-13-2013)
