can the circuit breaker finder be used in the old house fuse panel? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
  • 1 Post By drsparky
  • 4 Post By samgregger
  • 1 Post By PlugsAndLights
  • 1 Post By Semi-Ret Electrician
  • 1 Post By telsa
Old 01-08-2017, 07:53 PM   #1
Rewards Points: 344
Default can the circuit breaker finder be used in the old house fuse panel?
has anybody tried that?
mike883 is offline   Reply With Quote
Old 01-08-2017, 08:09 PM   #2
drsparky's Avatar
Rewards Points: 320
Should, but can always make you own. Plug in a drop light with Cooper BP1008 Button Flasher under the bulb. Then look for the pulsing circuit with a clamp on amp meter at the panel.
The Following User Says Thank You to drsparky For This Useful Post:
Semi-Ret Electrician (01-08-2017)
Old 01-08-2017, 08:51 PM   #3
Rewards Points: 681
or put an old door bell transformer and a bell on a 4 square box and put a cord on it. Plug it in and when you hear the bell stop ringing you shut off the right circuit.
Old 01-08-2017, 09:03 PM   #4
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,218
Why don't they sell plug testers with this built into them?
P&L
Majewski likes this.
Old 01-08-2017, 10:55 PM   #5
Semi-Ret Electrician's Avatar
Rewards Points: 388
I put a box together that if connected between a fuse or breaker and the branch circuit it would turn the circuit on an off.
Another way would be to have a helper flip the breaker on and off
Old 01-08-2017, 11:18 PM   #6
Rewards Points: 2,928
I wanna be able to plug in a little device and then hear ''Gimme Three Steps'' playing when I wand the proper breaker on the other end.
Old 01-08-2017, 11:22 PM   #7
Rewards Points: 388
I sometimes hook my greenlee toner around a circuit and trace wiring, in an attic, all the way back to a panelboard, never leaving the 1st floor.
telsa likes this.
Old 01-09-2017, 01:04 AM   #8
Rewards Points: 12,460
Edison fuses = ancient = tiny...
Typically < eight circuits.
An extension cord and a plug tester -- works, too.
Lighting circuits are easy, as they are on switch legs.
There are so FEW residences dependent upon Edison fuses -- there's no reason to trick things up.
I don't work that end of the street, but I'd kill off every fuse box I run into. Policy, that's all.
chadnodine (01-09-2017)
Old 01-09-2017, 01:19 AM   #9
When I see a fuse box, I know the insulation is falling off the conductors. A knob and tube each and every time around here. Having said that though, I remember the house I grew up in located in Florida had a fuse box at one point before upgrade. It was wired with old 1960's two conductor romex, so my first sentence only applies to my area.
telsa (01-09-2017)
Old 01-09-2017, 01:53 AM   #10
Rewards Points: 7,154
I dunno about a circuit breaker finder but a jobsite radio cranked up loud on a metal station works.
Never tried it but a jobsite radio or shop vac with walky talkies could work too (walky talkies are cheap).
Old 01-09-2017, 01:58 AM   #11
Deplorable-Electrician
Rewards Points: 18,762
Yes and it worked fine.
DJT, making libtards cry since 20 Jan 2017
Arc fault option Anathera General Electrical Discussion 175 07-08-2016 06:35 PM
for side job: how much charge for changing the fuse panel to 100A breaker panel? mike883 General Electrical Discussion 38 06-13-2016 11:49 PM
Upgrading and outdoor screw-in fuse box to a circuit breaker type box Jimmi328 Residential Electrical Forum 2 03-26-2016 08:09 PM
Is this overkill? MTW NEC Code Forum 81 03-20-2016 09:26 PM
