Old 11-04-2009, 09:31 PM   #41
EDM
EDM's Avatar
Originally Posted by steelersman View Post
Hey, I'm not a hack. Peter D is the hack.
Peter D is my friend, it even says so in my profile.
I'm going back to work on Friday, no more time for foruming. Bye everyone!
EDM is offline   Reply With Quote
Old 11-04-2009, 09:33 PM   #42
steelersman's Avatar
I feel very sorry for you.
steelersman is online now   Reply With Quote
Old 11-05-2009, 12:36 AM   #43
Originally Posted by Magnettica View Post
Btw, can Cat5 also be used as speaker wire?
It's not intended to be used as speaker cable, but there are a lot of people out there who believe Cat 5 makes some of the best speaker cables. They try lots of things like braiding and paralleling to extract the 'best sound'. It's cheaper than high-end speaker cable. Google Cat5 speaker cable and you might be surprised. Maybe it has to do with the skin effect on many small conductors since a speaker cable is carrying AC.
I tried it with my speakers and it worked well but my experimental pair of cables was too short, so I let my friend have them.
Old 11-05-2009, 09:36 AM   #44
The reason you wire cat 5e according to the color code is that each pair is twisted to a different amount of twists per inch. This enables the data to be transmitted with less errors. BTW standard telephony is A for voice and B for data.
Old 11-05-2009, 10:28 AM   #45
says who?.....provide documentation
Old 11-05-2009, 10:47 AM   #46
Horse**** I say. They have same amount of twists per inch. Now maybe that is the difference between the different CAT's but not for different pairs in the same cable.
Old 11-05-2009, 10:57 AM   #47
Here you go. Enjoy the info.
Category 5e
Cat 5e cable is an enhanced version of Cat 5 that adds specifications for far end crosstalk. It was formally defined in 2001 as the TIA/EIA-568-B standard, which no longer recognizes the original Cat 5 specification. Although 1000BASE-T was designed for use with Cat 5 cable, the tighter specifications associated with Cat 5e cable and connectors make it an excellent choice for use with 1000BASE-T. Despite the stricter performance specifications, Cat 5e cable does not enable longer cable distances for Ethernet networks: cables are still limited to a maximum of 100 m (328 ft) in length (normal practice is to limit fixed ("horizontal") cables to 90 m to allow for up to 5 m of patch cable at each end, this comes to a total of the previous mentioned 100 m maximum). Cat 5e cable performance characteristics and test methods are defined in TIA/EIA-568-B.2-2001.
Individual twist lengths
By altering the length of each twist, crosstalk is reduced, without affecting the impedance.
Pair color[cm] per turnTurns per [m]Green1.5365.2Blue1.5464.8Orange1.7856.2Brown1.9451 .7
8P8C modular plug pin positioning
TIA/EIA-568-B.1-2001 T568A WiringPinPairWireColor131white/green232green321white/orange412blue511white/blue622orange741white/brown842brownTIA/EIA-568-B.1-2001 T568B Wiring[1]PinPairWireColor121white/orange222orange331white/green412blue511white/blue632green741white/brown842brown
Old 11-05-2009, 10:58 AM   #48
EDM
EDM's Avatar
jw0445, welcome to the forum. Thanks for the info.
Old 11-05-2009, 11:00 AM   #49
[12]
Old 11-05-2009, 11:05 AM   #50
Ok. I concede.
Direct buried 1k ft run of electric, fiber, data(cat5e) and Voice (Cat3) -same trench sj22 Structured Wiring 11 10-03-2008 10:36 AM
