Old 08-02-2009, 12:03 PM   #1
petek57's Avatar
Default Ceiling fans so simple yet?
In troubleshooting an Emerson ceiling fan recently I opened up the light/speed switch area and found the speed switch shattered in pieces inside. Simple me decides to pick up a speed switch from a big box store to replace. Lo&behold I have to figure out which wire goes where. Never did figure it out satisfactorily. Ended up installing a remote which took care of everything.
The question is how do most ceiling fan speed switches work? There was a solid state device also in this "junction area" I am guessing that is where the speed is controlled. What could I have done differently?
petek57 is offline   Reply With Quote
Old 08-02-2009, 12:19 PM   #2
No, multiple taps of the motor. The numbers molded in the switch might not be in the same place on the replacement switch, but make the wire that was in "2" before go in the "2" hole on the new switch, etc.
Old 08-02-2009, 10:37 PM   #3
PGW Professional
Magnettica's Avatar
The 1, 2, and 3 positions just add more coil turns to make the motor run faster right?
Old 08-02-2009, 10:46 PM   #4
I don't see how repairing a ceiling fan is cost effective. Seems to me, it is a remove and replace, throwaway item.
Old 08-02-2009, 11:00 PM   #5
mattsilkwood's Avatar
if its a high dollar fan i can see replacing a $5 switch.
Old 08-02-2009, 11:07 PM   #6
Yeah, price a Casablanca fan cd a switch.
Panasonic Fans mikeg_05 General Electrical Discussion 7 06-12-2009 09:53 AM
Baseball Fans Chris Kennedy Off Topic 13 04-20-2009 07:34 PM
Old Casablanca Fans.. Mr. Sparkle General Electrical Discussion 2 04-07-2009 08:37 PM
ceiling fans ce2two General Electrical Discussion 16 03-21-2009 12:32 PM
Vetalation fans philip657 UK Electrical Forum 0 12-30-2007 11:15 AM
