Old 04-13-2007, 07:22 PM   #1
Default Code for commercial stair case lighting
Whats the code on installing fluorescent light fixture in building stair case? Do you put a three way switch?
Alex is offline   Reply With Quote
Old 04-13-2007, 07:29 PM   #2
use a pull chain and long string then you can turn the light off no matter what tread you are standing on....
Is this a fire rated stairway?
Public egress?
Typically lights would stay on all the time.
Old 04-13-2007, 07:30 PM   #3
Resi or commercial? If commercial, is the building over 5,000 square feet or under 5,000 square feet? 24 hour operation? Or, closed overnight?
Or, you could use a long pull-chain run through pulleys as necessary.
Old 04-13-2007, 09:09 PM   #4
most commercial building staircases are for fire/emergancy egress, because of this most fixtures are on 24/7 and either have a bodine or bug eyes on the wall incase of power outtage.
Old 04-14-2007, 11:29 PM   #5
Licensed Pro
Magnettica's Avatar
I smell bacon.
Do you smell bacon?
Quality means doing it right when no one is looking.
Henry Ford
CAPS and lower case brian john Off Topic 6 11-15-2009 02:30 PM
Just in case you were wondering, now is not the time to recycle copper TOOL_5150 Business, Marketing, and Sales 8 11-14-2008 12:27 AM
National Electrical Code: Analysis & Explanation of the Underwriters' Electrical Code Joe Tedesco Vintage Electrical 3 12-28-2007 11:47 PM
Commercial ?'s I need help with brybedo General Electrical Discussion 41 11-21-2007 12:33 AM
Energy conservation code and lighting MDShunk Lighting Design 4 08-04-2007 01:53 PM
