Old 01-16-2011, 04:07 PM   #1
Default Color Code On USB micro???
So I have this USB micro cable I just snipped and I noticed something odd. Instead of the standard Red, Black, White, Green wires there's Red(pink?), Yellow, White, and light green. Anyone know what role each of these colors are assigned? I can't find anything about it online. And unfortunately the manufacturer is unknown.
leestover is offline   Reply With Quote
Old 01-16-2011, 04:17 PM   #2
vos
vos's Avatar
I would plug it in and use a dmm and see which two are +5vdc and ground. Then use a normal usb wiring diagram and see if any of the outer colors mach.
vos is offline   Reply With Quote
Old 01-16-2011, 04:22 PM   #3
Heavily Armed Member
HARRY304E's Avatar
Click this link it may help..http://www.accesscomms.com.au/reference/usb.htm
Welcome to the forum
Old 01-16-2011, 04:28 PM   #4
Registered Big Member
mxslick's Avatar
Also bear in mind that in a molded cable assembly where both ends are prewired the manufacturer could use whatever colors they want, as long as the terminations are correct and the wire characteristics meet spec. (Impedance, capacitance, current carrying, shielding, etc.)
I have had to cut up premade parallel data cables (DB25) and they have all had different wire color standards.
Freshly manscaped for your motocross riding pleasure.
mxslick is offline   Reply With Quote
Old 01-16-2011, 04:39 PM   #5
Thanks guys. I used a spec of a USB pin layout and matched it up to the wires using a cont. tester.
Micro & Island outlet BIGRED General Electrical Discussion 62 03-12-2010 10:13 AM
FYI For SeeSnake Micro Owners KayJay Tools, Equipment and New Products 49 08-04-2009 07:38 AM
Use whatever color you have. Adam12 Code Violation Discussion 20 04-15-2009 08:17 AM
color codeing stillirnin General Electrical Discussion 17 07-06-2008 07:09 PM
color code question goose134 UK Electrical Forum 16 12-20-2007 11:31 PM
