03-10-2009, 05:33 AM
Concrete Anchors
Whats the best concrete anchors for supporting a pipe rack,
I used 3/8" drop in anchors which have a 4100lb pull out value, which seemed to work well. I hope they will be strong enough to support my rack.
I'll have several 1/2" and 3/4" conduits and 1 - 3 1/2" conduit on the rack I was planning on providing extra support for the 3 1/2" conduit with minnies and rod.
Any one have any suggestions on good concrete anchors?
03-10-2009, 06:54 AM
"A" inside wireman
We always use drop ins for that type of hanging. Hilti shot in 3/8" studs for lighter hanging.
"One Nation Under God"
03-10-2009, 10:02 AM
I dunno how big is your rack?
03-10-2009, 05:01 PM
3/8ths drop in or wedge anchors.
When ls lunch
03-10-2009, 05:13 PM
[quote=calimurray;63867]Whats the best concrete anchors for supporting a pipe rack,
Well 3/8 anchors are good enough we also use 1/2 sometimes but we run buss duck with just 3/8 anchors and were talking double stacked aluminum 4000 amp each if its copper buss we use 1/2 go for it your fine . we use the 1 inch length 3/8 there not coming out ever. take care
03-10-2009, 07:33 PM
Those drop in anchors work great, you are talking about 8200lbs of weight per stut support. You have a small rack for needing anything more then that.
I am just working on a rack with ten 3" and we are just using the 3/8 anchors. I can even stand on the rack (but dont tell the boss  )
I'll have to take a pic, its a nice looking rack.
03-10-2009, 08:00 PM
Dont do this !
Well we took a tapcon once and drilled it into a 3000 psi concrete deck then took a chain fall and hooked a chain up to it , guess what ? It pulled out but it took two of us to pull the chain and the force was unreal ,the 1/4 inch tapcon pulled out with a chunk of concrete we then did the same with a 1/4 anchor it did not come out we could not turn the chain on the chain fall . now that lots of force i trust a 3/8 anchor for just about anything we use it on our tuggers ,large wire pullin pulleys , rigging switchhgear set on pads and transformers at over 5000lbs most mechcanical contractors use these on heavy pipe work like chiller pipes but 1/2 inch now thats a lot more weight then a electrical conduit . we just got a new self drilling screw it screws into concrete by itself using a 1/2 hammer drill and has a 3/8 threaded coupling on its end dont know the name of it anyone know ? best to ya
03-10-2009, 08:50 PM
Unlimited Lic.Electrician
I'm a big fan of lead anchors or I think there also called wedge anchors.
03-10-2009, 10:39 PM
Me too; they expand the most of any anchor. The problem is that in a fire, they will melt and the rack will fall. They're often prohibited for overhead anchoring just for that reason.
When I have heavy crap to anchor overhead, I let the guys at Fastenal spec the anchoring system. They give you a little print detail and the whole nine yards if you ask. Adds another person to blame later on if anything ever goes wrong.
03-10-2009, 10:55 PM
Could it have been the ITW Sammy Screw?
They have a self-drilling threaded rod hanger like that for concrete.
03-11-2009, 12:50 AM
I prefer sleeve anchors. The depth of the hole isn't as critical.
03-11-2009, 06:47 PM
yes it looks like a sammy screw but concrete type .best to yas
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
anchors
calimurray |
Union Topics |
0 |
03-10-2009 05:27 AM |
E.M.T in concrete
Bailey 167 |
Code Violation Discussion |
9 |
11-22-2008 05:33 PM |
anchors
paul d. |
NEC Code Forum |
6 |
09-01-2008 12:24 PM |
Red concrete...
Hellerex |
Other Codes and Standards |
16 |
07-29-2008 08:39 AM |
concrete lightpole base's?
Bradley |
8 |
04-01-2008 09:20 AM |
