Originally Posted by BuzzKill
I don't think the OP is talking about anything having to do with pools or hot tubs; the sleeve anchor he mentions needs to be bonded somehow to an EGC to clear any ground fault, or dead short.
I am talking about bonding a hot tub to the existing concrete pad. I was wondering if one could use the anchor that I put in the original post would suffice. I don't have an 08 code book yet, as we are graded on 05 currently, so I am not up on the changes.
In another post a guy said something about Bonding the hot tub to the concrete pad. This sounds to me like the frame of the hot tub is to be Bonded to the EGC and the concrete slab, not Bonding the concrete slab to the GEC(which would Earth/Ground the slab). I don't know if that is the case or not. If all your doing is bonding the frame to the pad I cant see why that little anchor is any worse than the suggestion that William put forth.
