08-27-2009, 08:59 PM
Concrete in PVC
Slurry overpour has found its way into 1" pvc for pole base in concrete parking lot. Any tricks or advise on getting it out?
08-27-2009, 09:05 PM
Ohhhh... that sucks. You could try vinegar. I have only heard of that, not sure if it works. I have used muriatic acid to get concrete out of pipes. That stuff is serious and not to be taken lightly. It will burn your skin and cause blindness if you get it in your eyes. When I use it, I flush the pipe from the other end with water where practical, and if not, I pour a lot of baking soda and water solution in the offending end, then use the wet vac to clear it out.
Also, a piece of fishtape run to the obstruction and then chucked into a drill can sometimes beat the concrete loose.
08-28-2009, 12:42 AM
 1 7/8" X 4' bit on the hilti drill on an angle from center of the base so it comes out down low and run a new pipe.
08-28-2009, 12:58 AM
Seen your member
Usually, the bulk of the stuff is outside the base itself, so can you dig down and replace the pipe itself? Even if there's a little bit in the pipe that's in the concrete base, there won't be much to deal with and a short fish tape in a cordless might be enough to do it.
Using a fishtape in a drill is very unsafe, however, and you should wear eye protection and heavy clothes.
08-28-2009, 09:03 AM
Wyome
Vinegar has already been suggested, I have also heard coke works,  , you know the stuff you drink.
08-28-2009, 09:59 AM
Run an old peice of fish tape you don't care about down until it hits the concrete. Cut it to length and use it as a drill bit, drill awhile, then hit it with your vac, then repeat until obstruction is cleared. Takes awhile but I have cleaned them out like this in the past.
08-28-2009, 01:11 PM
Originally Posted by lectricboy
Run an old oeice of fish take you don't care about down until it hits the concrete. Cut it to length and use it as a drill bit, drill awhile, then hit it with your vac, then repeat until obstruction is cleared. Takes awhile but I have cleaned them out like this in the past.
I can tell you have been around for quite awhile in this business. That how I have always done it. And I have had to do it many times.
08-28-2009, 04:50 PM
Will an M80 fit into a 1" conduit
This is why I seal off all open ends and pour the bases myself. I will sometimes duct tape the couplings to lesen the chance of separation when the concrete is poured.
I've never had it happen but I would try the vinegar or acid first. If it's just a little bit it may break up and dislodge.
Other solutions?
Determine how far down the plug is. You may be able to expose the conduit underground right at the base and work it from there.
If you have conduit in and out, you may be able to install a jbox and ose only one feed to the pole.
Worst case, you have one feed and it is actually separated. Then it's exposed conduit, drill a tricky hole or a yank it and pour a new base  .
08-28-2009, 04:55 PM
Unlimited Lic.Electrician
Thats how I would fix the problem.
08-28-2009, 04:58 PM
Apprentice
There is less citric acid in coca cola than in orange juice.
Just sayin'.
Philly Carpetbagger
08-28-2009, 08:08 PM
Electrical Contractor
Fishtape and drill has worked for me several times, its a hit and miss depends on how much crete and rocks really made it in. You said slurry. The tape will get slurry not too many rocks. Heard of the vinegar many many times in 20 years. Vinegar never was laying around on the jobs.We always had a tape and a drill and a helper, I was the helper several times. But in conversation with Old Schoolers I DO mean that respectfully!! I remember them talking about barrels of vinegar. Big pipes, long runs, parallel in a duct bank that had to be cleared.
I didn't write the books, I just read the books,
And look at the purdy pictures
08-28-2009, 08:14 PM
In the 70's when I first started in the trade we used blasting caps for EMT in concrete decks. This only works for small obstructions.
I have heard of all the other methods noted, and all can work depending on the amount of slurry
The only way you will know is to try them starting with the simplest first.
Or do the ultimate and get a shovel if this is feasible.
I void warranty's
08-28-2009, 08:15 PM
The fishtape in a drill is the standard method.... Right after you ream the guy who didn't tape up the stubs a new anal cavity.
08-28-2009, 08:22 PM
Motor Repair&Control Shop
I use that stuff all the time cleaning the aluminum on my 4-wheeler.
And for a supplement to "WEED B GONE"
When somethings broke, I wanna put a bit of fixin on it
08-28-2009, 10:13 PM
The muriatic acid does work. Had a conduit that got concrete in it and we had to have that conduit and we put the acid in the conduit and let it set for a week and after letting it set for a week we were able to get the wire thru.
08-28-2009, 10:16 PM
Originally Posted by MDShunk
...... Right after you ream the guy who didn't tape up the stubs a new anal cavity.
You got that right.
08-28-2009, 11:48 PM
Mad Skills
...with the drill and fishtape?
08-29-2009, 05:04 AM
#18
And the vinegar....
08-29-2009, 07:59 AM
#19
Thanks to all with advice. Used a combo of all of the above. Fish tape in drill cleared after soak of vineger. Not sure which had most effect but at the time, I didn't much care. Vacuumed and pulled wire. . Thanks again!
By the way, I really was considering the M-80 post!!
Paul
08-29-2009, 08:57 AM
#20
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Concrete burns
George Stolz |
Off Topic |
30 |
06-20-2009 08:55 AM |
Concrete Anchors
calimurray |
11 |
03-11-2009 06:47 PM |
E.M.T in concrete
Bailey 167 |
Code Violation Discussion |
9 |
11-22-2008 05:33 PM |
Red concrete...
Hellerex |
Other Codes and Standards |
16 |
07-29-2008 08:39 AM |
concrete lightpole base's?
Bradley |
8 |
04-01-2008 09:20 AM |
