Old 01-04-2008, 09:59 PM   #1
sparkysteve's Avatar
Default Conduit in block
I'm starting a job Monday roughing-in conduit stubs in 8" block walls. I'm mostly a residential guy with some comercial experience and haven't done much work in masonry walls. I've done plenty of pipe running/bending, just not in walls. How long do you guys usually cut your pieces of pipe for in the wall? Any other tips or tricks? Thanks
sparkysteve is offline   Reply With Quote
Old 01-04-2008, 10:34 PM   #2
Mad Skills
Celtic's Avatar
Originally Posted by sparkysteve View Post
I How long do you guys usually cut your pieces of pipe for in the wall?
About 9' long
Don't piss of the blockheads with 9' nipples
Seriously, no more than 3 - 4'...the blockheads have to lift the pipe over your stub....if they prefer it a bit longer/shorter they'll let you know.
Keep a coupling (or two) handy at ALL times that is covered on one end w/duct tape or similar to keep loose/falling cement out of the pipe.
A cup of coffee/cold drink goes a long way with men in the trenches
Old 01-04-2008, 10:42 PM   #3
9' might make them angry. Brickies are kind of a grumpy bunch anyway. I've just only done it once or twice and wondered if there was anything I didn't know. I know of some guys who get picky and only cut pipe in lengths that are multiples of 8 so they can bend and cut a buch of offsets and 90's and always have them come out in the bottom of a block.
Old 01-04-2008, 10:48 PM   #4
Not Banned Yet
BryanMD's Avatar
I'm assuming these are homeruns of conduit to be under a slab that then are to turn up inside the web of the CMU? To then connect to a J-box? For recepticle/switch boxes etc?
If so... you better plan to be there when that first course is laid and have a sample box with a stub of conduit on it for each mason to use as a gage for setback depth and so the conduit lines up with the webs (especially for the lower boxes).
(Oh man, do I ever hope you did your conduit layout from the same plans the masons have.)
March 2010: On the road with my RV. California is first primary destination then it is off to Eastern OR, Northern ID and Western MT for drycamping and fly fishing until Labor Day.
Old 01-05-2008, 08:22 AM   #5
"A" inside wireman
randomkiller's Avatar
I'd say 40" is good and you will have to be there the whole time. to be sure it is done right
"One Nation Under God"
Old 01-05-2008, 08:46 AM   #6
Nothing is run underground. Everything is getting stubbed up into the ceiling.
Old 01-05-2008, 10:16 AM   #7
Bkessler's Avatar
Try and get all your pieces pre cut and ready to go if possible, if you know how high your ceiling is it's not to tough and be ready for the brickies to not like you very much. And make sure you have 1.5 and 2" mud rings if your using 4's boxes.
When ls lunch
Old 01-05-2008, 12:52 PM   #8
Good advice Bkessler, ceiling height is a good thing to know in every area youll be stubbing into. I also like to have my grounding pigtails screwed into the boxes before they are installed (tough to get in after boxes are sealed in concrete). I also find it helpful to duct tape the mounting holes in the back of the boxes to prevent concrete from running in them or the conduits in the box. Also some bailing wire I found can come in handy keeping the boxes flush with the concrete, just run a piece of wire through the mounting holes in the mudrings and slide a piece of wood in between the block and the wire to hold it out flush. It might not be a bad idea to get a peak at the mechanical drawings( tough to extend your pipe when its behind a duct). And I have found you have to always be present when the blockies are there laying or could be big trouble.
aksparky is offline   Reply With Quote
Old 01-05-2008, 09:58 PM   #9
Make up your masonary boxes ahead of time.
Put a ground pigtail in them NOW. Much easier than later.
Duct tape the opening to keep out mud.
The shorter you make them, the happier the masons will be. They usually dont complain about 40-48 inches.
Lots of standing around then hauling ass. They DON'T like to wait so stay on top. Piss em off and mortar will somehow find it's way into your conduit.
Bring doughnuts and beer or burritos and cerveza depending on your location.
Old 01-05-2008, 11:43 PM   #10
Pierre Belarge's Avatar
All good advice.
I worked with brickies and the best advice I can give it to be prepared...they do not wait. Try to make an attempt at friendship, it can only help.
Pierre Belarge is offline   Reply With Quote
Old 01-07-2008, 10:07 PM   #11
Joe Momma's Avatar
Duct tape every coupling, connector and box.
I like 2 foot lengths to keep them happy and to keep me busy in the mean time.
Have your boxes premade with pigtails and tape, and stubs premade with coupling and tape (if they have to wait on you they won't like you)
The above tip for tie wire and piece of wood to keep boxes flush is a very good one.
And also, 'bond beams' are the ideal place for lateral runs, but the inspector will probably not like it, so keep the brickies informed on where your stuff needs to be and they'll set bond beam blocks wherever you need them(they prefer to use the pre-notched blocks rather than waiting on the guy below to cut custom blocks, just another 'slowing them down' issue)
Joe Momma was here
Old 01-08-2008, 04:41 PM   #12
Thanks guys. It is defititely boredom and action. We even had a rain day today. So far so good.
Old 10-01-2009, 10:41 PM   #13
what does 460/60/3 mean is it 60amps or 60 htz
dominician is offline   Reply With Quote
Old 10-01-2009, 11:02 PM   #14
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
This is the second time you have asked this exact same question. stop it
~Matt
Old 10-02-2009, 01:20 AM   #15
I used to take em all out to the bar once in a while if I had to work with any mason company on a repeat basis. Soon they were assisting me so well I didn't have to stay on the job. Wiskey was cheaper back then.
Old 10-02-2009, 01:59 PM   #16
It's been a long time since I did any work like this, but I remember working alongside of the block masons. I was setting boxes from slab stubs and running straight up from stubs. The key was to be there the whole time. They pretty much worked around me. I installed a conduit or box, they blocked around it. Never had any problems with them.
Old 10-02-2009, 02:13 PM   #17
If you have a lot of drops on a day when there are multiple block layers working, another handy thing to have around is a Greenlee hot box. Keep some sticks in there at various lengths inserted rolling around and pull and run as required.
Old 10-02-2009, 03:51 PM   #18
bored member
BuzzKill's Avatar
...and make sure your couplings are wrench tight; don't use the screwtype either. Nothing worse than fishing into a wall and realizing your pipe came undone.
BuzzKill is online now   Reply With Quote
Old 10-02-2009, 04:56 PM   #19
Mad Skills
Celtic's Avatar
Duct tape does what a screw driver or wrench cannot
Old 10-02-2009, 05:21 PM   #20
Seen your member
Best advice I can give....... plan at least a day in advance.
If you show up at 7 AM and start looking at the plans, assembling boxes, cutting sticks of pipe, trying to figure out what to do where...... and then head out to the scaffold, you're already too late.... the brickies will already be 5 or 6 courses up and are ready to hop up. Do all this stuff the day before. Have everthing preassembled and ready to go. Have extra boxes and pipe and fittings handy so if something gets destroyed, you can just turn around and replace it with no pause in the work flow.
Always put your ground tails in the boxes before heading out to the scaffold. If you wait until you pull wires, you'll never get them threaded in.
Many times, the first course of block is already laid, so they can just start piling one on top of two and two on top of one. And it is common for this first course to end up below the slab when it's poured. So if this is the case, you can make whatever marks you want on that course. Forget using sharpies....... get some crayons.
ALWAYS try to plan where your boxes go so they're right next to a mortar joint. Brickies truly hate cutting boxes in in the middle of a CMU. Also, cut your conduit to the correct length so it stubs out at a joint as well. This way, whoever lays that block can just 'notch' it with their hammer.
If you've got various heights of boxes to work with, take some time to cut the first stick of pipe to a specific length so once the box is set, all the pipes are the same height above the current course.
A cordless sawzall is almost a necessity if it's a large job. Take a short piece of #4 solid bare and make an S-hook so you can hang it somewhere handy.
The scaffold belongs to the brickies, and it's their 'turf'. Tread lightly while you're there. Stay out of the way, but keep a close eye on their progress. Be ready to step up when they need you to attach another stick of pipe or set a box.
I know I'll catch some h-e-double toothpicks for this, but if you're just standing around watching, don't hesitate to help them out if it is appropriate. I don't mind getting someone a bucket of mud if their laborer is tied up somewhere else, or handing them a level that's just out of their reach.
Brickies are a different breed. Make 'em happy, and the job goes as slick as snot on a doorknob. Tick 'em off, and you'll be miserable, even long after they have taken their towers down and moved on....... if you get my drift.
A dozen doughnuts once in a while goes a long way as well.
Conduit for UPS bman4523 Code Violation Discussion 7 02-05-2009 12:08 PM
New Guy on the block rnspark Introductions 7 07-10-2008 05:24 PM
mental block stillirnin General Electrical Discussion 9 01-25-2008 09:16 PM
Conduit Fill Roger123 General Electrical Discussion 10 10-10-2007 10:08 PM
Masonry cinder block switch boxes wiremeup General Electrical Discussion 17 06-03-2007 07:31 PM
