Old 05-01-2012, 01:22 PM   #1
Default Conduit over solid rock
Job task is to run conduit for a subpanel feeder from the house to the end of a walkway, at the edge of the lake. The first 50' is an easy trench, but the remaining 250' is over mostly solid rock. Plan to use Sch 80 over the rock, but unsure of the best way to attach the conduit to the rock.
Alternative is to attach the conduit to the walkway, but the serpentine nature of the walkway would almost double the length and require upsizing the wire even more.
Ideas and suggestions welcome.
normel is offline   Reply With Quote
Old 05-01-2012, 01:39 PM   #2
1,000,000th Poster
Big John's Avatar
I imagine pipe mounted on the ground will probably have to take a lot of abuse.
I'd use rigid on mallable standoffs with a couple of expansion couplings.
-John
Old 05-01-2012, 01:41 PM   #3
Fill dirt?
Old 05-01-2012, 01:55 PM   #4
acro's Avatar
I say get creative with your conduit bender and do it in metal with concrete anchors
acro is offline   Reply With Quote
Old 05-01-2012, 02:00 PM   #5
One glob of wet concrete every____ or so feet placed over the conduit and rock will hold it down ok. A method used often over exposed lava flows.
Bare rock gets hot like roofs do. Depending on the load, you may want to consider de-rating the wire.
Still sweeping it up: http://www.myfoxorlando.com/story/22...-still-unclear
chicken steve (05-01-2012)
Old 05-01-2012, 02:16 PM   #6
The area is wooded so not too worried about heat, but not sure how well the concrete would take hold over rock with a few inches of dirt, moss, etc. over it.
Old 05-01-2012, 02:24 PM   #7
acro's Avatar
I like the concrete idea, but you would have to clean the rock down to bare with water for good adhesion, but that would be a good alternative.
When you said schedule 80 - I assumed pvc. Is that correct?
Old 05-01-2012, 02:30 PM   #8
Originally Posted by acro View Post
Well, you would have to clean the rock down to bare with water for good adhesion, but that would be a good alternative.
Correct, PVC with expansion couplings.
Kinda like the concrete idea the more I think about it.
Old 05-01-2012, 02:34 PM   #9
Coffee drinking member
Wirenuting's Avatar
The concrete is a good idea to hold the rigid down. But I would lift the pipe off the rock by about 1/4 - 1/2". It will keep it from rotting away. Drill a 1/4 hole in the rock below we're the concrete will go. Drop a galvanized screw, rod in it to get your hight. This also helps the concrete hold to something and not slide around.
Hydraulic ( water plug ) cement works great.
edit: never mind the rot, I just saw the PVC statement.
Old 05-01-2012, 04:04 PM   #10
Sparkypyro's Avatar
Can you go overhead from tree to tree to the last tree THEN down to the ground?
Sparkypyro is offline   Reply With Quote
Old 05-01-2012, 04:17 PM   #11
Hillbily style
Shotcrete/Gunite. If the budget is good, cover the whole run and camo paint it.
Old 05-01-2012, 04:22 PM   #12
979
ahhhh Sounds like bermuda... if you go with concrete you may want to go with a few more expansion couplings depending on how the seasons are where you are at.
979 is offline   Reply With Quote
Old 05-01-2012, 04:45 PM   #13
Sparkypyro's Avatar
Originally Posted by 220/221
Hillbily style
If its ok for the government to do it in state parks rather then plopping down poles should be ok for a home provided the proper materials are used. I would imagine it would look WAY better and last a lot longer than running it over rock. I have seen this done in my travels all over the country.
Old 05-01-2012, 04:56 PM   #14
cant you use armored cable with pvc jacket? In canada we use teck cable a lot for any outside application
Old 05-01-2012, 05:54 PM   #15
1,000,000th Poster
Big John's Avatar
If its ok for the government to do it in state parks rather then plopping down poles should be ok for a home provided the proper materials are used....
Though I think it could be done safely, check out 225.26
-John
nolabama (05-01-2012)
Old 05-01-2012, 05:57 PM   #16
The Tarzan approach? I don't think the good doctor who's signing the check will go for that.
Old 05-01-2012, 06:10 PM   #17
Nec 2011 225.26
Vegetation such as trees shall not be used for support of overhead conductor spans
Nebelectrician is offline   Reply With Quote
Old 05-01-2012, 06:10 PM   #18
B4T
ET Road Warrior
B4T's Avatar
I would use RMC instead of PVC on top of solid rock.. it just gives it more protection when you're between a rock and a hard place..
The Following 2 Users Say Thank You to B4T For This Useful Post:
normel (05-01-2012), Wirenuting (05-01-2012)
Old 05-01-2012, 06:14 PM   #19
I agree. This time.
I'm innocent. I did nothing wrong. I'll take the fifth.
Old 05-01-2012, 06:29 PM   #20
B4T
ET Road Warrior
B4T's Avatar
Originally Posted by Chris1971 View Post
I agree. This time.
Are you sure.. .. I mean you are making a decision without the help of others..
Best decade for rock music Chris1971 Off Topic 47 01-01-2012 04:22 PM
Rock of ages Zog Off Topic 2 12-31-2011 02:13 PM
Ultimate and Rock Solid interiors ??? HVAC Controls Residential Electrical Forum 17 07-20-2011 07:02 AM
For those old f's that still rock Chris Kennedy Off Topic 5 05-16-2011 07:27 AM
#10 solid in conduit Conduit Phil General Electrical Discussion 60 05-16-2010 01:45 PM
