Old 08-01-2007, 07:09 AM   #1
Default Consumer Unit Location
Please could you let me know what the maximum distance allowed is between the electric meter location and the consumer unit to comply with current regulations?
Stuart
sturharv is offline   Reply With Quote
Old 08-01-2007, 04:16 PM   #2
frank's Avatar
2 mtrs Stu.
Old 08-01-2007, 06:04 PM   #3
sparkysteve's Avatar
I think it's 5' inside the house without a disconnect. Really no limit if you run outside.
sparkysteve is offline   Reply With Quote
Old 08-02-2007, 04:07 AM   #4
Thanks very much
Old 08-10-2007, 04:34 AM   #5
I need about 8m from the meter before a suitable location for the consumer unit!
Firstly, can this be done? would it need a sub-main? what extra expense is involved in doing it this way ££?
Thanks
Stuart
Old 08-10-2007, 11:51 AM   #6
frank's Avatar
It can be done. You need a switch fuse at the meter head and a sub main circuit of 16mm or 25mm from this to your Consumer Unit.
Costs . I don't know.
FRank
Old 08-10-2007, 11:59 AM   #7
Thanks Frank
Old 08-14-2007, 04:35 AM   #8
Frank,
We are going to use a built in wall box, will the switch fuse be located in the meter box, or will it be located remotely adjacent on the wall?
Kind regards,
Stuart
Old 08-14-2007, 12:42 PM   #9
frank's Avatar
I suspect the Supply Co will not let you use their meter box to fit your switch fuse isolator. You will need to fit a another box adjacent.
Old 08-17-2007, 08:07 PM   #10
best checking with your local DNO!
general matters is offline   Reply With Quote
UK: consumer unit swill20 UK Electrical Forum 6 04-11-2008 06:09 PM
Consumer Unit to Head distance NewCross General Electrical Discussion 3 07-31-2007 02:53 PM
consumer unit . soddy General Electrical Discussion 2 07-29-2007 11:10 AM
Cute little Square D Consumer Unit frank Services and Service Equipment 5 06-15-2007 02:38 PM
Moving consumer unit query!!! maxkd General Electrical Discussion 12 03-15-2007 04:25 PM
