controlling attic fan? - Electrician Talk - Professional Electrical Contractors Forum
Old 04-23-2010, 10:23 PM   #1
Rewards Points: 530
Default controlling attic fan?
What variable speed control device would you guys use for a small whole house ventltor fan with a 115v 2.3 amp motor? Have tried hi med low Broan bath fan controller and didnt work well. Any info appreciated.
Old 04-23-2010, 10:25 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Most whole-house fan manufacturers make a two-speed controller.
Old 04-23-2010, 10:26 PM   #3
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,536
...that or what comes with it? a temp setting/regulator?
I'd rather be sleeping.
Old 04-23-2010, 10:33 PM   #4
Les Voltage
If when you say "didnt work well" you mean, didnt pull much air. You need to make sure it has a way for the air flow both ways.
If not, disregard
Old 04-23-2010, 10:34 PM   #5
Rewards Points: 530
Your right, instead I failed to mention it has a 2 speed pull-chain switch but barely differentiates between the two. I was wondering what controller would do a better job at that?
Old 04-23-2010, 10:49 PM   #6
Rewards Points: 5,198
Can you just install a two temperature setting switch in the attic and just forget about it?
Old 04-23-2010, 10:55 PM   #7
Rewards Points: 518
Are you talking about an attic fan or a whole house fan?
crazyboy is offline   Reply With Quote
Old 04-23-2010, 10:58 PM   #8
cdnelectrician's Avatar
Rewards Points: 1,018
Boy that thing is helluva ugly! Wouldn't want to see that on my bathroom wall!
Old 04-23-2010, 11:02 PM   #9
Rewards Points: 2,012
As posted- you need air in to get air out. Normally one would use a line volt T-stat- with an over ride feature.Or the device provided with the unit.
Old 04-23-2010, 11:04 PM   #10
Who puts whole-house fans in bathrooms?
Old 04-23-2010, 11:08 PM   #11
Les Voltage
Whole house fans dont work like that. You dont want them to pull out the bought air.
Old 04-23-2010, 11:12 PM   #12
I thought he said attic fan...my bad.
Old 04-23-2010, 11:16 PM   #13
Les Voltage
My house is sealed tight, when I put my WHF in I had learn the hard way how they work. My system is perfected by doing it the wrong way the 1st time.
Old 04-23-2010, 11:19 PM   #14
Mine is an attic fan that mounts through the roof; The temp. controller actuates the fan when the heat gets to 95 degrees.
Old 04-23-2010, 11:27 PM   #15
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,114
when I installed my whole house fan, I just used a 3 way switch to control the 2 speeds, and a timer to control on/off.
~Matt
I HAVE THE RIGHT TO OFFEND ANYONE I PLEASE. YOU HAVE THE RIGHT TO BE OFFENDED, YOU DO NOT HAVE THE RIGHT TO SHUT ME UP.
Old 04-24-2010, 03:02 AM   #16
Circumcised Member
idontknow's Avatar
Rewards Points: 250
What about a ceiling fan remote control? They're about $30-40 and give 3 speed control.
idontknow is offline   Reply With Quote
Old 04-24-2010, 11:47 AM   #17
Rewards Points: 250
probably not designed to handle the current drawn by a whole house fan.
there are fan speed controls for higher amperages available - it must be a PSC type motor but most usually are. If two speed motor most cases I would use the two speed taps and a double throw switch (could use std 3 way but will need additional on - off switch.
There are automatic controls that vary the speed based on temperature, they will be pricey compared to a manual controller. I commonly see these controlling ventilation on livestock buildings and up to 1/2 hp or even more will not necessarily have the "look" desired in a home and most likely in a NEMA 13X enclosure.
kwired is offline   Reply With Quote
Old 04-24-2010, 11:51 AM   #18
not THAT old!
Electric Al's Avatar
Rewards Points: 250
Yes, there are controls. e.g. Honeywell makes one. It is a thermostat that closes on temperature rise. Commonly used in cattle barns etc.
Electric Al is offline   Reply With Quote
Old 04-24-2010, 12:14 PM   #19
OK, it seems there's some confusion as to what kind of fan is involved here.
Is it a whole-house fan, that is installed in the ceiling of the top floor......
......... is controlled by a pull-chain or a wall switch, and designed to cool the living space of the house?
OR, is it an attic fan that is not visible from the finished areas.........
...........that is controlled by a thermostat and is designed to remove heat from the attic only?
Old 04-24-2010, 12:46 PM   #20
Rewards Points: 3,855
I normally use a make-on-temperature-rise line voltage wall stat and a 3-way switch to pick which speed.
Best Attic Suprises Mike Guile General Electrical Discussion 30 03-06-2010 03:45 AM
Attic Romex tie-in rmsowell Residential Electrical Forum 13 11-23-2009 09:49 PM
Controlling direction on VFD Ferrari_man PLCs, VFDs, Motors and Controls 12 11-16-2009 11:27 PM
Firestat for attic ventilator B4T Residential Electrical Forum 4 06-08-2009 06:52 PM
Wires in the attic... waco General Electrical Discussion 5 09-08-2008 10:11 PM
