Cooper vs Leviton vs P&S - Electrician Talk - Professional Electrical Contractors Forum
Old 11-14-2010, 01:13 PM   #1
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Default Cooper vs Leviton vs P&S
Which of these three common manufacturers do you think is the better product in the line of standard receptacles, GFCI outlets, residential decora devices.
I personally prefer Cooper or P&S. Leviton is poor quality but not as poor as these Chinese knock off Decora outlets my customer purchased at the Hardware store.
Old 11-14-2010, 01:19 PM   #2
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
I always use Leviton.. they have been based here on Long Island for many years and their tech support guys have English as a first language.
Old 11-14-2010, 01:23 PM   #3
220/221's Avatar
Rewards Points: 3,578
We've used P&S for about 15 years now.
I installed a customer provided GFCI recep last week (Leviton?) and it had a green LED on all the time. It bothered the customer so I came back and installed a P&S which has the more logical, red if tripped.
I like that the P&S decors style switches have side wire, tab terminals. I wish everything had them, including the grounds.
You use tech support for receps and switches? You should call and ask them if the ground goes up or down.
Old 11-14-2010, 01:28 PM   #4
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
My beef with leviton SP and decora 3 way......12 wire will often cause switch to either stay on or not go on at all when in a tight box, figuired the device might be queer.
Old 11-14-2010, 01:30 PM   #5
Jesus Scott
electricmanscott's Avatar
Rewards Points: 232
The answer to the OP is a matter of opinion with no right or wrong answer. I use P&S but mainly because it's what my supplier carries.
Life is hard
Old 11-14-2010, 01:31 PM   #6
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
P&S whenever possible
Old 11-14-2010, 01:31 PM   #7
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
I always use Leviton their quality has really improved in resent years.
I agree about the gfci and the LED light on 24/7 it should only go on when triped.
Old 11-14-2010, 01:39 PM   #8
Toronto Sparky's Avatar
Rewards Points: 1,008
Green light is supposed to indicate... Safe For Use
Don't fight .. Play nice!
Old 11-14-2010, 01:40 PM   #9
B4T
B4T's Avatar
My customers like the green light.. shows the GFI is working when they test it once a year..
Old 11-14-2010, 01:58 PM   #10
Ayuh
Ima Hack's Avatar
Hubbell would be my first choice, P&S is what I usually use.
Good electricians aren't cheap, cheap electricians aren't good.
Ima Hack is offline   Reply With Quote
Old 11-14-2010, 02:32 PM   #11
drsparky's Avatar
Rewards Points: 494
P&S have an odd front on the receptacles. Also P&S have "top" stamped on the yoke, to me that is a manufactures instruction and means only ground up.
Old 11-14-2010, 02:34 PM   #12
Mostly Harmless
Split Bolt's Avatar
Green means GO, red means STOP!
I don't care what LED color code they use, but I wish they would agree on a universal color!
My normal supplier carries mostly Leviton, but P&S GFIs and Bryant 20 amp & twist lock stuff. (and Lutron dimmers) Don't like 20 amp switches that aren't framed...looks cheesy to me. I especially hate when I see a framed and unframed switch under same plate.
I've never had to call tech support for installing a device either!
"Golf is a good walk spoiled." -Mark Twain
Split Bolt is offline   Reply With Quote
Old 11-14-2010, 02:41 PM   #13
I own stock in FotoMat!
Rewards Points: 6,520
P&S all day long.
I always use Leviton their quality has really improved in resent years......
Well, when you make nothing but absolute junk, you can only make it better, not worse.
Speedy Petey (11-14-2010)
Old 11-14-2010, 02:43 PM   #14
drsparky's Avatar
Rewards Points: 494
Framed? I see those and know they used the least expensive cut rate devices they could buy. It makes me wonder what other corners were cut that I can't see. I don't do residential but use spec grade in my own home.
Old 11-14-2010, 03:00 PM   #15
Mostly Harmless
Split Bolt's Avatar
I can't stand how they look. Leviton makes framed 20A switches. Pretty sure they are spec grade. I'll have to check. I guess you say tomato, I say tomato!....wait, that doesn't work in type!
Old 11-14-2010, 03:05 PM   #16
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I've also had problems with , "one time" use from leviton GFI smart lok. Seems that many trip and never reset, completely dry locations. I had a bad batch of Cooper GFCI this Spring.
Old 11-14-2010, 03:32 PM   #17
evil bastard
Rewards Points: 746
Tomāto, Tomäto
Split Bolt (11-14-2010)
Old 11-14-2010, 04:33 PM   #18
etb
Rewards Points: 250
Hubbell when they can afford it.
etb is offline   Reply With Quote
Old 11-14-2010, 04:40 PM   #19
Rewards Points: 3,855
P&S.
It would be hard to argue that their cover plates aren't the best on the market at the moment.
Old 11-14-2010, 04:57 PM   #20
Always Learnin'
I used to use Leviton for resi and Hubbell for ind/comm because that's what was available at my supply house. I changed supply houses a few years ago and have been using P&S for everything since then. Every manufacturer has their low-end crap line like $.40 duplex recepts but I don't use them.
amptech is offline   Reply With Quote
Alternative to Leviton 51120-1 TVSS? Mr. Sparkle General Electrical Discussion 11 09-19-2010 08:07 PM
For Sale: Leviton 20a GFCI, Lot of 20 mattsilkwood Electrician Swap 4 09-12-2010 05:14 PM
LEVITON Trimatron 3-wy dimmer danickstr General Electrical Discussion 5 06-29-2010 01:32 AM
Leviton Decora & Home Dope-o BIGRED General Electrical Discussion 23 10-28-2009 09:50 PM
Cheetah/Leviton manchestersparky General Electrical Discussion 4 06-24-2009 09:38 PM
