Old 04-14-2009, 05:20 PM   #1
Default Cutler-Hammer breaker
Panel make-Cutler-Hammer
Cat# 4030
120/208V 125A 3PH 4W
Circuit breaker class type list: class NI, CH, & CH2100 safety breakers
Approximate year of panel installation: 1964
Type of breaker needed: CH115GFCI
Type of breaker purchased: CH115GFCI
The breaker purchased will not not seat onto the bus properly.
Does anyone know where we can find or maybe have the part number of a GFCI breaker that will work.
NYXLAR is offline   Reply With Quote
Old 04-14-2009, 07:48 PM   #2
redbeard43's Avatar
if this is easier, pull the circuit you want protected into a box next to the panel and install a receptacle, cheaper than a breaker.
You have the ring, and I see that your schwarz is as big as mine.May the schwartz be with you!
redbeard43 is offline   Reply With Quote
Old 04-14-2009, 08:34 PM   #3
Professional Nit Picker
If you can get a regular breaker that fits, you could alway set a small sub panel. Then you can use a GFCI that is designed for the newer panel.
Maybe a small 4 circuit sub?
Old 04-15-2009, 11:04 AM   #4
Only time I ever hit a snag with CH breakers, it was in the "wrap around" that holds the breaker at the connection end. Seems like it was a metal lip that protruded into the space. I honestly can't remember, but if altering the panel isn't an option, then I agree with setting a sub-panel to accept the newer breaker.
Klein Hammer mikeg_05 Electrician Swap 57 06-04-2009 12:23 AM
Cutler Hammer All in One and 350 MCMs Joefixit2 General Electrical Discussion 3 11-13-2008 10:49 PM
cutler hammer Louieb General Electrical Discussion 6 11-08-2008 08:59 AM
DeWalt Hammer drill Chris Simms Tools, Equipment and New Products 8 08-11-2008 11:29 PM
funny looking hammer paul d. Off Topic 14 07-17-2008 05:50 PM
