Old 04-02-2009, 10:32 PM   #1
Golden Arc's Avatar
Default DC and receptacles
Sorry this may be an even dumber question that the other thread. Are receptacles DC current?
Golden Arc is offline   Reply With Quote
Old 04-02-2009, 11:18 PM   #2
No but the value we measure is a representative of the equivalent heating effect of DC, Peak of 120 VAC is 169, the RMS is 120 VAC.
Old 04-02-2009, 11:21 PM   #3
Seen your member
I've don't think I've ever seen a receptacle with a DC rating.
Old 04-02-2009, 11:33 PM   #4
Sure you have; forklift battery chargers!
I know what you mean though, I highly doubt any of the normal receptacles are DC rated.
An AC arc is self-extinguishing, well up to a certain voltage it is anyway, a DC arc is not. I wouldn't want to pull the plug on a high current DC circuit.
Rob
Old 04-03-2009, 08:18 AM   #5
Rob
DC Arcs are self extinguishing if you pull the contacts far enough apart. AC Arcs are not always self extinguishing above 360 VAC the arc will re-ignite, which is why we have GFP on 480 vac systems and do not require them on 208. The peak of the sine wave on a 208 system does not approach this value.
Old 04-03-2009, 02:36 PM   #6
www.diychatroom.com
Old 04-03-2009, 06:11 PM   #7
Golden Arc's Avatar
Contacts? Are you talking about the blades on the plug?
Old 04-03-2009, 06:16 PM   #8
The blades on the plug and the inside of each slot in the receptacle/outlet are considered the contacts in this situation...
Shaffer87 is offline   Reply With Quote
How many receptacles an a circuit patriot1 General Electrical Discussion 5 03-19-2009 06:46 PM
Pigtails for Receptacles duke2043 NEC Code Forum 2 06-09-2008 09:45 PM
AFCI Receptacles calimurray NEC Code Forum 21 05-16-2008 10:04 PM
Afci Receptacles calimurray General Electrical Discussion 17 03-17-2008 05:58 PM
Childproof Receptacles Nosparxsse NEC Code Forum 13 01-26-2008 09:44 AM
