Old 11-15-2011, 06:12 PM   #1
Dug
Smile Difference between 51G, 51Gs, 51N Relays
I was wondering what the difference is between 51G, 51Gs, and 51N Relays? In addition, how do they relate to current transformers (How could you tell which is which based on a schematic of a power system or other ways)?
Dug is offline   Reply With Quote
Old 11-15-2011, 06:33 PM   #2
A little google
http://www.aeusp.com/fundamentals/dvprgo.asp
The three most commonly used connections for ground-overcurrent relays are the residual connection (51N), the ground-sensor (balanced-flux or zero sequence) connection (50GS or 51GS), and the neutral current transformer connection (51G).
It should be simple to identify the current transformers from the schematic (if the drawings are accurate).
Brian John
Leesburg, VA
Old 11-15-2011, 08:50 PM   #3
Electron Flow Consultant
sparky970's Avatar
http://www.csanyigroup.com/ansi-stan...ection-devices
The Following User Says Thank You to sparky970 For This Useful Post:
Dug (02-24-2012)
Tags
51g, 51gs, 51n, current transformer, relay
have a question about relays fw541c General Electrical Discussion 14 04-29-2011 02:00 PM
FACP relays.. B4T General Electrical Discussion 4 06-30-2010 08:51 AM
Wiring Relays Toledo Services and Service Equipment 3 11-26-2009 10:51 AM
Relays alselec General Electrical Discussion 6 11-13-2008 08:54 PM
contactors/relays Gavin Adams General Electrical Discussion 23 08-29-2008 12:54 PM
