03-24-2008, 11:52 AM
difference between the afci breaker and the new combination afci
whats the difference between the AFCI breakers and the new combination AFCI breakers there coming out with
03-24-2008, 12:14 PM
Chief Electron Relocator
From the GE web site: - Branch/Feeder AFCI
A Branch/Feeder AFCI has the ability to detect and neutralize a parallel arc fault, which is the unintentional flow of electricity between two separate wires. There are three types of parallel arc faults: line-to-line, line-to-ground, and line-to-neutral. The Branch/Feeder AFCI is permitted by the 1999-2005 NEC® Code.
Combination AFCI
GE's Combination AFCI delivers 5 kinds of protection:- Parallel protection – Just like its Branch/Feeder counterpart, Combination AFCI can detect and neutralize parallel arc faults
- Series Protection – A series arc fault is the unintended flow of electricity over a gap within a single wire. These arc faults were not detectable until advanced technology allowed the development of the Combination AFCI breaker.
- Ground protection – Arcing between a single conductor and a ground line
- Overload protection
- Short circuit protection
The 'old' AFCIs only detected an arc between two wires, line-ground, line-line, and line-neutral. The new ones detect an arc within a single wire (loose connection).
03-24-2008, 08:17 PM
Also, the ITE (I hope other manufacturers have this feature or are working on it) combination breaker has LEDs to indicate what type of fault it is.
Oh yeah, the other difference is the combo unit is about $10 more.
04-19-2009, 08:03 AM
Afi readme
this may help
Combination AFCI
Wood alcohol: Cannot be made non-poisonous.
Of all the lessons dad could have left out...
04-19-2009, 08:38 AM
Combination AFCI
AFCIs also protect against the use of some vacuum cleaners as well.
John from Baltimore
"One day at a Time"
04-19-2009, 02:56 PM
About ten bucks!
-KB
04-19-2009, 06:40 PM
ITE? I'm assuming you mean Siemens/Murray.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
NEW type of AFCI.
MDShunk |
8 |
12-21-2011 01:26 PM |
AFCI Receptacles
calimurray |
NEC Code Forum |
21 |
05-16-2008 10:04 PM |
Afci
corkers |
5 |
02-28-2008 11:41 PM |
Afci Combination
ANDY |
16 |
12-27-2007 03:52 PM |
Afci Breaker trips.
Hillbilly |
17 |
04-17-2007 10:01 AM |
