12-31-2007, 12:19 PM
Do we need neutral for 240 volts oven or air-condition system
Some electrical oven state in the installation instruction that the neutral and ground can be bounded together and suggest to look at local code requirements
In Los Angeles County when I call the electrical code hotline some inspectors are saying that old appliances used to be connected with ground only but this requirement has been changed and now you must put neutral as well, other inspectors say to use the manufacture suggestions. When I asked electricians 20-40 years in the business they give the same answer. Some say that it is ok to omit the neutral for an air-conditioned but not for an oven
Does anyone know the requirement?
Ophir Amor
Amor electric
http://www.amorelectric.com
gil@amorelectric.com
12-31-2007, 01:01 PM
Ophir, I don't mean to sound rude, but you possess an electrical master's license in California, yet you don't know this part of the code?
This is pretty basic stuff. If an appliance requires a neutral it requires a neutral. There is no ambiguity here.
OLDER codes had an exception where a household cooking appliance or dryer, that was 120/240v rated (meaning two hots and a neutral), could have the ground bonded to the neutral. This allowed SEU cable to be used or X/3NM cable without ground.
In these cases a neutral was ALWAYS required. Anyone saying that you could use only a ground was flat WRONG. The exception allowed the omission of the ground, NOT the neutral.
This exception has been gone for several code cycles and ANY new circuit rated 120/240v requires separate ground AND neutral conductors.
If a circuit is a straight 240v, such as an A/C, water heater, electric motor, etc, then NO neutral is or ever was required.
12-31-2007, 02:51 PM
Mad Skills
What a specific appliance will require is specific to the appliance....however, a rather "safe" rule of thumb is:
- 99% of the time you need a neutral at an oven
- 99% of the time you don't need a neutral for an AC - not talking about some through the wall/window model....talking compressors, ducts, air handelers, etc.
The neutral-to-EGC connection IS allowed ONLY in certain installations:
From the '05 NEC:
250.140 Frames of Ranges and Clothes Dryers.
Frames of electric ranges, wall-mounted ovens, counter-mounted cooking units, clothes dryers, and outlet or junction boxes that are part of the circuit for these appliances shall be grounded in the manner specified by 250.134 or 250.138.
Exception: For existing branch circuit installations only where an equipment grounding conductor is not present in the outlet or junction box, the frames of electric ranges, wall-mounted ovens, counter-mounted cooking units, clothes dryers, and outlet or junction boxes that are part of the circuit for these appliances shall be permitted to be grounded to the grounded circuit conductor if all the following conditions are met.
(1) The supply circuit is 120/240-volt, single-phase, 3-wire; or 208Y/120-volt derived from a 3-phase, 4-wire, wye connected system.
(2) The grounded conductor is not smaller than 10 AWG copper or 8 AWG aluminum.
(3) The grounded conductor is insulated, or the grounded conductor is uninsulated and part of a Type SE service entrance cable and the branch circuit originates at the service equipment.
(4) Grounding contacts of receptacles furnished as part of the equipment are bonded to the equipment.
This image from Mike Holt illustrates 250.140:
http://mikeholt.com/freegraphics.php?id=gvb
Of course, a local amendment can trump a NEC requirement.
01-01-2008, 08:38 AM
"A" inside wireman
I have heard a rumor that the board of examiners that administer the Electricians testing in Ca have done a study that shows if the test questions are too hard many applicants may develope a severe head ache that may result in brain tumors somewhere down the line, so they stick to the simple ones.
ie: if you open a box and have a black, red, and white wire...you get the idea.
"One Nation Under God"
01-01-2008, 09:26 AM
Do the tests have a warning label:
WARNING: These tests have been known to cause severe headaches in the state of California.
01-01-2008, 10:55 AM
I think they have cause headaches in other states too...
John from Baltimore
"One day at a Time"
01-01-2008, 11:04 AM
Yeah, but they only cause cancer in California.
01-01-2008, 11:06 AM
From all the smoking, alcohol and drug use the stress causes, I guess....
John from Baltimore
"One day at a Time"
01-01-2008, 10:42 PM
"A" inside wireman
Maybe it's just being in Cali that causes cancer in lab tests, I know I felt sick there after just talking to a few people.
01-02-2008, 12:17 AM
Go ahead and make what you want of this but I passed both the ca journeymens and contractors without studying. And each one took less than an hour. My Michigans j-mans I studied on my own for six months and I used every second available and just squeeked by.  In other words this as close to right to work as you can get.
When ls lunch
01-03-2008, 01:02 AM
"A" inside wireman
That's what I had figured in relationship to a CA test. I bet they have more study guides in Spanish than english available.
01-03-2008, 09:34 AM
You got it, RK because the journeymens test is knew to the state, they gave an extra year to people takeing the spanish version to comply. WHAT the f@#$?
When ls lunch
01-03-2008, 10:48 AM
Don't worry about the language. In 50 years all Americans will be speaking Spanish and you English speakers will be the ones to get the extra year !!!!!
01-03-2008, 05:48 PM
"A" inside wireman
Maybe we should leave the country long enough to get citizenship somewhere else and then come back and become repatrioted to get the benefits immigrants get.
01-03-2008, 06:39 PM
Do you think the OP is a real electrician. He has a really nice website, if I didn't know any better I would hire him. Other than the fact that he doesn't even know how to wire the range or an air Conditioner.
01-03-2008, 09:35 PM
RK finally a topic it sounds were in total agreement. Bk
When ls lunch
01-05-2008, 12:27 PM
List you license number on your website so the Contractors Board doesn't bust you. Suggest you get rid of the "low price" so you don't attract bottom feeders.
01-05-2008, 07:36 PM
#18
Duplicate post. Now I know how not to do that.
#19
If we pay for the tea we ruined, can we come back there?
01-05-2008, 09:03 PM
#20
