Double Float Switch - Electrician Talk - Professional Electrical Contractors Forum
Old 05-26-2011, 08:27 PM   #1
chris856's Avatar
Rewards Points: 260
Default Double Float Switch
I've wired a few septic systems using a line voltage double float switch and have no problem on how to wire and test them.The one thing I am a little fuzzy on is how exactly they work.
I know when the tank level rises high enough and raises the first float nothing happens.
When the level gets high enough to raise the second float, the circuit closes and the pump starts running and draining the water.
The water level falls enough to lower the top float and the motor still runs.
The motor stops running when the the tank level is low enough that both the top and bottom float are down.
The one thing I don't know is what keeps the circuit closed after the top float goes down.
This is a basic switch and uses no control wires.
chris856 is offline   Reply With Quote
Old 05-26-2011, 08:35 PM   #2
Jlarson's Avatar
Rewards Points: 2,958
Lots of those floats have a relay molded into the cord. It acts just like a stop start push button set up. You have a contact in parallel with the top float that acts as the start switch and the bottom float acts like the stop switch.
Old 05-26-2011, 08:38 PM   #3
Rewards Points: 416
The first floats only purpose is to pull out a relay- sort of like a stop button. When it raises it does nothing but when it drops it pulls out a relay that was energized by th on float. So you have a start and stop switch.
I see Jlarson beat me to it.
Old 05-26-2011, 08:42 PM   #4
chris856's Avatar
Rewards Points: 260
Thanks guys.
Old 05-26-2011, 09:43 PM   #5
Rewards Points: 1,000
You're welcome. <wink>
Roadhouse is offline   Reply With Quote
Duel float septic pump John Brylinski General Electrical Discussion 8 01-19-2011 10:31 AM
130 VDC float switch Jlarson General Electrical Discussion 0 04-20-2010 08:23 PM
Low-voltage 3-way double dimmer switch, does it exist? lysforude Residential Electrical Forum 28 12-29-2009 02:33 AM
any idea's for a parade float? personal Off Topic (Non Trade) 13 12-02-2009 06:01 PM
Float switch with start stop override pudge565 PLCs, VFDs, Motors and Controls 34 10-12-2009 10:14 PM
