Dryer cord,Range cord ? - Electrician Talk - Professional Electrical Contractors Forum
Old 06-06-2012, 01:34 AM   #1
Davethewave's Avatar
Rewards Points: 158
Default Dryer cord,Range cord ?
Why do they call a 30 Amp. cord a Dryer cord and a 50 Amp. cord a Range cord? A dual fuel range is 30 Amps. Do I use a Dryer cord or a Range cord. Is there a special cord for a welder? Why don't they call them 30 Amp. and 50 Amp. cords?
Davethewave is offline   Reply With Quote
Old 06-06-2012, 03:45 AM   #2
erics37's Avatar
Rewards Points: 640
So the homeowners can figure out which one they're supposed to get when they're staring at the appliance cords at Home Depot.
You can always make your own cords, too.
The Following 3 Users Say Thank You to erics37 For This Useful Post:
BIGRED (06-06-2012), Celtic (06-06-2012), chicken steve (06-06-2012)
Old 06-06-2012, 07:07 AM   #3
Rewards Points: 576
It is just more descriptive. Instead of bringing out the nema charts and trying to give the number it is easier to use these terms since they are standard plugs. Used to be the range only had a 50 amp and the dryer only a 30 amp.
On a 30 amp dual fuel you can use anything that is rated 30 amps and 4 wire but you will probably pay more for the other configurations then you will for the dryer receptacle. Also the cords are pre made in those configurations so unless you want to spend the time making cords just use them.
Old 06-06-2012, 12:56 PM   #4
Rewards Points: 1,810
Well it is a little more than that too. A range cord may have #8 hot wires and #10 neutral. Very specific to a range.
Old 06-06-2012, 03:34 PM   #5
Going_Commando's Avatar
Rewards Points: 334
Really?
Why do they call it a switch box? Does that mean you can't install receptacles in it? Use your noggin, fella. You have the most powerful computer in the world resting atop your neck, but you gotta push the right buttons to make the thing work.
ETA: Fixed for Harry's needy personality
Old 06-06-2012, 03:35 PM   #6
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I use "dryer" cords all the time for dual fuel ranges.
Old 06-06-2012, 04:15 PM   #7
Rewards Points: 576
I have a dual fuel range by Bosch and it requires a 50 amp circuit. Crazy.
Old 06-06-2012, 04:17 PM   #8
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
The ones I've come across are 30 amps. Did one of the early ones way back when, 4/3 SE cu cable 80 amp breaker.
Old 06-06-2012, 04:23 PM   #9
Rewards Points: 576
I assumed mine would be 30 amps also since it is just an oven-- I was surprised but I already had a #6 run there from the last electric range with 2 ovens.
I didn't check the wattage but it is interesting that I can have a range with 2 ovens that is all electric and it uses the same power as a dual fuel single oven--- dang.
Old 06-06-2012, 04:36 PM   #10
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Originally Posted by Going_Commando View Post
Really?
Why do they call it a switch box? Does that mean you can't install receptacles in it? Use your noggin, fella. You have the most powerful computer in the world resting atop your head, but you gotta push the right buttons to make the thing work.
It is in his head ,not atop of it...
Old 06-06-2012, 08:14 PM   #11
Rewards Points: 334
Ya happy now? I fixed it. I should leave the fancy talk to Steve.
For Sale : Electrical Cord/Extension Cord Lock-out Devices 480sparky Electrician Swap 16 09-03-2012 03:45 AM
Water Feature Pump-cord/cord cap hot to touch Jupe Blue General Electrical Discussion 29 09-08-2011 07:25 PM
Can a 9 ft. electrical dryer cord be bought or made that is safe? rhemshot General Electrical Discussion 6 06-26-2011 11:50 PM
Dryer and Range BIGRED General Electrical Discussion 30 07-11-2010 01:15 AM
Need to plug electric range 3 Wire Cord, Only have standard outlets?? Dav567 General Electrical Discussion 23 03-06-2010 07:04 AM
