Old 05-19-2011, 12:47 AM   #1
Default Earthing Systems in rural residential areas
Hi,
I'm new to the site. Does anyone out there know much about earthing in rural houses? I don't do much resi work let alone in the country and have only been in the industry 10 yrs.
I need to replace an old (1920's) DB in Australia and here's the interesting problem...there is a large bare cable bonded to the in-coming Neutral which disappears down the wall toward the DB (I thought this was a specific "in-the-country" earthing system), however, it doesn't come out in the DB . Anyhow, I am wondering how this kind or earthing system SHOULD be configured and whether, if I simply put an earth stake in, it will effect this system.
Any advice?
Chester00 is offline   Reply With Quote
Old 05-19-2011, 12:50 AM   #2
I void warranties
Jlarson's Avatar
Could it go to the rebar in the foundation? If the house is built like that, that is.
The best never stop learning.
Old 05-19-2011, 01:00 AM   #3
It's not built on a slab but but there is no room to get underneath as it is buit so low to the ground. Maybe it bonds to a water pipe and then to the board...there is a straggly little bare wire coming into the board with some solder on it but the sizing didn't look right to be the main earth... I should go and read my AS book...it is just so, er, open to interpretation that it doesn't help half the time and doesn't give info on old systems.
Old 05-19-2011, 04:15 AM   #4
kbsparky's Avatar
Do they still utilise skeleton systems in Australia? I never saw one until I spent a fortnight in outback Queensland several years ago ....
-KB
Old 05-19-2011, 05:07 AM   #5
Skeleton systems??
The house was wired in the old rubber/material insulated cabling and it was all run in metal conduits...most things including power outlets weren't earthed and someone had definately been "their own handy work"...not cool...
Old 05-19-2011, 05:09 AM   #6
Oh, there were some bare earthing conductors running about the roof which were very sparcely connected to stuff.
Old 05-19-2011, 09:53 AM   #7
Lightning rod system?
CraigV is online now   Reply With Quote
Rural HO's and DIY's, WOW mr_g Code Violation Discussion 9 02-09-2011 04:56 PM
Where do you prefer to live: City, Suburban, or Rural? Frasbee Off Topic 49 05-04-2010 12:16 AM
UK: explosive areas ben cammy UK Electrical Forum 3 01-05-2010 08:58 PM
Laundry Areas Shubey NEC Code Forum 19 11-06-2009 12:54 AM
chicago electrical contractor testing areas knaack21 General Electrical Discussion 3 04-02-2009 09:56 PM
