04-29-2012, 05:13 PM
Licensed Journeyman
Is this the easiest way to do this?
Have someone that wants a motion light that can be turned on, off and on the motion detector. My mind says a hand off auto is the only way to go. Tell me if I am wrong.
04-29-2012, 05:15 PM
methinks your right bama, despite the fact RAB's stealth heads boast the function asked....~CS~
04-29-2012, 05:19 PM
I usually in stall them with a switch...a quick on/off at switch will turn light on and it will stay on till ya turn it off for a few seconds then it defaults back to settings...is that what you mean???
Are those doughnuts for anyone??
04-29-2012, 05:21 PM
1,000,000th Poster
I'm with RGH. There are fixtures that come with this capability built in, all you have to do is wire them to a switch.
-John
04-29-2012, 05:24 PM
Rab is the only way to go, and I would put it on a switch also and maybe a switch guard if needed to protect it from being turned off by mistake
Licensed Journeyman
No, its around a basketball goal. Lady wants to turn it on and leave it on for bball. Its of course to high up to use the switch on the head.
04-29-2012, 05:30 PM
Gold Member
Feed it with a 3 wire from a 3way switch. Put a sp switch in ahead of the three way for 'power' Up is light on, down is motion light. Does this work for application?
Reason: Spelling
04-29-2012, 05:37 PM
Mostly Harmless
Just want to weigh-in on this real quick. RAB Stealth is the ONLY motion sensor I will supply. They cost 3x as much as the ones at the box stores, but are the most reliable by far! I always tell my clients I will provide RABs or install whatever they purchase, but RAB is the only ones I will guarantee. I made an exception a couple of years ago to a very nice elderly lady who is on a fixed income and really couldn't afford the RABs. I picked-up 3 Heath Zenith units @ the big blue box instead. Within the following couple of months, I had to replace 2 of them! Lesson learned!
"Golf is a good walk spoiled." -Mark Twain
The Following User Says Thank You to Split Bolt For This Useful Post:
Sideways Sparky
Most of them do exactly what you describe simply by using your standard single pole switch in accordance with the instructions. Ie on, off for so many seconds, back on and it stays on.
The only motion lights I have had luck with are heath zenith, never tried the rab before.
04-29-2012, 05:57 PM
well it would assume the HOA function in two devices....~CS~
04-29-2012, 06:19 PM
Licensed Journeyman
I tried that, thats what led me to the HOA. The three way and sp switch combo did not work.
04-29-2012, 06:20 PM
Licensed Journeyman
Whatcha mean?
04-29-2012, 06:21 PM
Chief Electron Relocator
SPDT-CO switch.
04-29-2012, 06:48 PM
Gold Member
Did not work how? Customer didn't like it? Because it def. Works electrically.
04-29-2012, 06:56 PM
Licensed Journeyman
SPDT-CO switch.
04-29-2012, 07:00 PM
Licensed Journeyman
I drew it out but it was either on or off. No motion, motion was feed from one leg of spdt switch. Light was fed from other leg. You say sp in front of three way, i put it as the break on the load side of the motion switch....
04-29-2012, 07:01 PM
Single Pole Double-Throw-Center Off.
04-29-2012, 07:02 PM
#18
Gold Member
I guess even simpler would be two sp switches in parallel, if the electronics could take it. Anyone ever tried that?
04-29-2012, 07:03 PM
#19
Licensed Journeyman
Thanks, now for the I am stupid part. What gives by energizing the load side of the motion switch? It does nothing cause the switch is NO?
04-29-2012, 07:05 PM
#20
Gold Member
No, sp on line side of 3 way should work fine.
Line-sp-line-3way-load(s)
The Following User Says Thank You to Ontariojer For This Useful Post:
