In Australia the only people allowed to do any electrical work are licensed electricians. To the extent that the letter of the law was a light globe needed to be changed by a licenced electrician in some states.
In the USA this varies from state to state, some places have no licensing, some allow home owners to do work, some much states stricter.
In addition even though we call it the National Electrical Code (NEC), not everyone accepts the code and write their own or modify the NEC.
To become a licensed electrician you need to complete a four year apprenticeship working for a licenced electrician. There is no classes of licences ie once you are an A grade you can perform any electrical work. So you could for example spend your entire apprenticeship changing lights in supermarkerts get you licence and then wire up a factory.
Varies from no requirements to 4-5 years depending on the program you are accepted in. We have a limited license in some locals for HVAC and low voltage wiring (TV Computer ect...)
phase to neutral voltage 230V (nominal however actually 240V)
phase to phase 400V (nominal however actually 415V)
208/120 and 480/277 commercial, there is some 240/120 delta high legs and 5 wire two phase around.
240/120 residential single phase
earthing is MEN (multiple earthed neutral)
PLEASE EXPLAIN
WE HAVE NO EARTH, We are America the center of the universe. We call it ground though IMO earth would be a better term as there is a lot of confusion regarding grounding and the grounding terms.
Neutral connected to earth at substation and at each installations main switchboard
Pretty much the same.
Colours Australian standard
COLOR not COLOUR
There is no madated color coding though recommended/standard
on 208/120
L1 Black
L2 Red
L3 Blue
Neutral/grounded conductr white
480/277
L1, brown yellow or orange
L2 yellow orange or brown
L2 orange brown yellow
THEN THERE IS PURPLE
Neutral white or grey
Ground Green or green with yellow stripe.
Colours IEC also acceptable generally seen in flexible leads
Active=phase or energized
